Recommended Battery Parameters, Mode of Power Input for Orin Nano Dev Kit
I am trying to run Nvidia Orin Nano Developer’s kit with a battery. From the user manual, it seems like the only option to supply power to the kit is via the DC power jack? Can you please suggest mAh voltage etc. for the battery? Would a 22.2V 5,000 mAh battery be safe to power the kit?
Secondly, from an initial search, I couldn’t find an off-the-shelf cable with DC jack on one side and battery connector such as EC5 on the other. If DC power jack is the only input source, can you please suggest a way to connect battery to the kit?
Hi, the supply way could only be DC jack. The input power should be in the range of 5v~20v. We don’t have such cable recommendation, maybe you can check it online or with the vendors in ecosystem: https://developer.nvidia.com/embedded/ecosystem
Thanks. I may have gotten incorrect idea from user manual of Orin Nano Developers kit that the USB-C is only for data purposes (and not for power). Thank you for clarifying.
Hi @hassaniqbal209 , sorry for misleading on this. The power supply of Orin nano devkit can only be DC Jack. I just updated the orignial post here.
