Recommended way to distribute a proprietary inference runtime + ROS 2 node on Jetson?
We are working on optimized AI inference runtimes for Jetson devices and I’m trying to understand the typical production deployment model.
Suppose we have:
Optimized model
Proprietary C++ runtime (.so)
ROS 2 node
Customer's ROS 2 system
We want to distribute the runtime to customers without providing its source code.
What is the recommended production approach on Jetson?
For example:
  1. .so + headers + ROS 2 wrapper
  2. Debian packages
  3. Docker/container image
  4. Prebuilt ROS 2 packages
  5. Complete application binaries
Containers seem convenient because CUDA, TensorRT, ROS 2 and other dependencies can be pinned together, but I’m unsure whether containers are commonly used for actual production deployment on robots or mainly for development and reproducible environments.
Ideally we’d also like to support multiple JetPack versions without making deployment too complicated.
For people shipping commercial software on Jetson, what deployment model have you found works best?
Hello @shintwl,
Welcome to the Isaac ROS forum and thanks for the post!
A reasonable starting point is to keep your proprietary inference library separate from a thin ROS 2 wrapper, then package them according to how customers integrate your software:
• Debian packages: useful when customers already maintain a native ROS 2 installation. Ship the runtime library and prebuilt ROS wrapper with explicit dependency versions.
• A versioned application container: useful when you want to provide a consistent inference environment containing your binaries, models, configuration, and user-space dependencies.
• Headers/SDK: provide these when customers need to compile their own integration against your runtime.
These options can coexist—for example, the same binary packages can also be installed inside your container. Containers do have a robot-deployment role. The older Isaac ROS deployment guide ( Isaac ROS Dev — isaac_ros_docs documentation ) explicitly describes packaging built ROS workspaces or Debian packages into runnable images for robots. The current Development Environment guide ( Isaac ROS Development Environment — Isaac ROS ) explains environment
management and Docker customization, while production behavior still needs validation with your complete application.
For multiple JetPack versions, start with a tested compatibility matrix and publish separate builds or image variants where needed. Containerization helps manage dependencies but does not itself guarantee compatibility across JetPack releases. If you use Isaac ROS packages, consult Getting Started ( Getting Started — Isaac ROS ) for supported combinations and binary installation, and Release Notes ( Release Notes — Isaac ROS ) when selecting releases.
