It depends on how you use system.img.raw
as to whether or not it works. By itself you cannot just copy system.img.raw
as a file. You have to actually press the bits from inside of system.img.raw
directly into the partition (not as a file, but as binary data), and although scp
can get this file to the Jetson, your use of rsync
is for individual files, not binary data.
This is something of an ad hoc comment (not really needed unless you are interested in what went wrong) without a particular order, but:
- If you have a binary image (such as
system.img.raw
), then you must usedd
to apply this to a partition.dd
works with binary data and the filesystem is unknown and irrelevant todd
rsync
requires a filesystem and looks at individual files and directory structure, sorsync
has no point in working withsystem.img.raw
(which is binary data on the outside, and includes a filesystem in its bits on the inside wherersync
does not look). - Sizes of files might differ with tool shown. Something like imperial/metric unit conversion, in some places you might see “
kB
” or “MB
”, which are base 10 multiples of 1,000 or 1,000^2; others use “KiB
” or “MiB
”, kibibytes or mebibytes, which are base 2 multiples of 1024 or 1024^2. Running out of space might be from creating a partition based on a base 10 abbreviation destination partition, versus a base 2 abbreviation of the size of files. Mixing units can result in unexpected filled space. - Partition sizes are not the amount destination space available unless you speak of binary data. Filesystems within a partition have overhead, and if you were to format a partition as
ext4
, then the available space (filesystem empty space) is less than the partition size (binary data size). Assuming a partition and the filesystem are the same size can result in unexpected filled space because of overhead. - Binary data has no apparent structure (something using the data would have to “know” what is in the data). On the outside “
system.img.raw
” is binary data. - Filesystems are a data structure (a tree of nodes and metadata to understand the tree). On the inside “
system.img.raw
” hasext4
tree structure. -
system.img.raw
, as a file, is binary data.dd
is the tool for this. The output location of thedd
command becomes structuredext4
data. -
system.img.raw
, once its contents are extracted and overwritten on a partition, is structuredext4
data. The operating system driver is the tool that understands a filesystem likeext4
, which in turn uses tools likecp
,scp
orrsync
to manipulate that data.
Since you have “system.img.raw
” as a file (it was copied via scp
) in “APP_b
”, I’ll give an example of one way to use this, but there are others. I will assume “APP_b
” (nvme0n1p2
) is mounted (letting the driver treat it as ext4
) at “/mnt/app_b
” (adjust for your case). I’ll assume that “APP
” (nvme0n1p1
) is mounted at “/mnt/app_a
You could create APP
via:
# You don't want to write to APP as a partition (rather than filesystem) with `dd` while
# it is mounted:
sudo umount /mnt/app_b
# While mounted APP_b is structred ext4 data. When accessing nvme0n1p2 directly it is binary data.
# Note that "block size", the "bs", is irrelevant other than being a bigger buffer for faster
# operation, and could be omitted:
sudo dd if=/mnt/app_b/system.img.raw of=/dev/nvme0n1p1 bs=10M
The above would overwrite all content on nvme0n1p1
, but because the underlying data is a self-contained ext4
filesystem, this means you’ve simultaneously formatted nvme0n1p1
as ext4
and also installed all files. You could then:
sudo mount /dev/nvme0n1p1 /mnt/app_a
(adjust for wherever you want to mount this)
At the moment APP_b
(mounted on “/mnt/app_b
”) is just a file and not extracted. You could now do this to mirror APP
to APP_b
# We are using rsync, so both source and destination must be mounted and treated as files.
# Keep in mind there are a lot of rsync options, this is just a kind of "blanket" case, but we have to start empty:
sudo rm /mnt/app_b/system.img.raw
sudo rsync -avcrltxAP --info=progress2,stats2 --delete-before --numeric-ids --exclude '.gvfs' --exclude 'lost+found' /mnt/app_a/* /mnt/app_b
One can actually use dd
to read on one Linux system, but write to another over the network (you could have skipped scp
to APP_b
, and skipped use of rsync
). Half of dd
can run on the host PC (reading), and the other half can run on the destination (the Jetson), and file copy of system.img.raw
can be skipped (dd
is binary image copy). If not for permission issues with remote login of user root
on Ubuntu systems this would be simple. I hate to mention this for your specific case, but if you want more comments on this, then see this article:
https://nfolamp.wordpress.com/2010/06/14/performing-backups-with-netcat/
The gist of the above URL says you could do a remote dd
directly from host to Jetson’s APP_b
and APP
. This is only true if you can get past the confusion of sudo
combined with ssh
or netcat
Note that if dd
of APP_b
system.img.raw
to APP
fails, then it means the partition of /dev/nvme0n1p1
is too small. Likely because of the use of base 10 or base 2 units. However, this might still succeed. Whereas the use of rsync
deals with files and overhead on ext4
, the use of dd
has no overhead and bypasses ext4
(though the underlying data creates ext4
, the data itself, as written, is just binary…it isn’t until you mount the ext4
that overhead matters).
Almost forgot: cpio
understands serial transfer of data, but is not so different from rsync
. It is not the fault of rsync
that your copy failed. Nor would cpio
do better. However, think of cpio
as the underlying tool within rsync
. cpio
is simplified rsync
with fewer bells and whistles.
