Could you please tell me how to recompile imagenet-camera after change
DEFAULT_CAMERA -1
to
DEFAULT_CAMERA 0 as show me in V4l2
/jetson-inference/imagenet-camera/imagenet-camera.cpp is the correct file to modify?
DEFAULT_CAMERA -1
to
That’s correct, this is the right file to modify.
After making the change and saving then file, run these commands:
$ cd jetson-inference/build
$ make
Thanks for your answer, after changing the resolution in
gstCamera* camera = gstCamera::Create(640, 480, DEFAULT_CAMERA);
and compiling, it works for a few seconds and shut down the whole board.
Do you think the problem is the power supply?
Can I change power mode to high without a fan and the same micro USB power supply?
Hi RojasMilo, if it shuts down the whole board, that points to a power supply issue.
You can try putting your board in 5W mode (the default mode is 10W), and see if the issue goes away:
$ sudo nvpmodel -m 1
Run that before running imagenet-camera and it will put the board in 5W mode. If the board doesn’t power off this time, that means you probably need to try a better power supply before using 10W mode.
Thank you, Dustin, it works perfectly
