Record 2 video streams while capturing snapshots at a given interval
Hi
I am using the below pipeline to record and preview 2 1080p streams. I need to include a method to capture images at a given interval (3s) in this pipeline from the 2 sources.
gst-launch-1.0 -e v4l2src device=/dev/video0 ! tee name=t1 t1. ! queue ! video/x-raw, width=1920,height=1080, framerate=60/1 ! videorate ! video/x-raw, width=1920, height=1080, framerate=30/1 ! nvvidconv ! queue ! nvv4l2h264enc maxperf-enable=1 bitrate=4000000 profile=4 ! queue ! h264parse ! queue ! mux. alsasrc device=“hw:2,0” ! tee name=a1 ! queue ! audio/x-raw ! queue ! audioresample ! “audio/x-raw,rate=44100” ! queue ! voaacenc ! queue ! mp4mux name=mux ! filesink location=eed1mp1080HWNA.mp4 v4l2src device=/dev/video1 io-mode=2 do-timestamp=true ! tee name=t2 t2. ! queue ! image/jpeg,width=1920,height=1080,framerate=30/1 ! videorate ! image/jpeg,width=1920,height=1080,framerate=30/1 ! nvv4l2decoder mjpeg=1 ! nvvidconv ! video/x-raw,width=1920,height=1080,framerate=30/1 ! nvvidconv ! queue ! “video/x-raw(memory:NVMM),width=1920,height=1080,format=NV12” ! nvv4l2h264enc maxperf-enable=1 bitrate=4000000 profile=4 ! queue ! h264parse ! queue ! mp4mux ! filesink location=eed2mp1080HWNA.mp4 videotestsrc pattern=black ! video/x-raw,width=320,height=240 ! nvvidconv ! queue ! comp.sink_0 t1. ! queue ! video/x-raw, width=1920,height=1080, framerate=60/1 ! videorate ! video/x-raw, width=1920,height=1080, framerate=30/1 ! nvvidconv ! queue ! “video/x-raw(memory:NVMM),width=960,height=540,format=NV12” ! queue ! comp.sink_1 t2. ! queue ! image/jpeg,width=1920,height=1080,framerate=30/1 ! nvv4l2decoder mjpeg=1 ! nvvidconv ! video/x-raw,framerate=30/1 ! nvvidconv ! queue ! “video/x-raw(memory:NVMM),width=960,height=540,format=NV12” ! queue ! comp.sink_2 nvcompositor name=comp sink_0::width=1920 sink_0::height=1080 sink_1::xpos=0 sink_1::ypos=270 sink_1::width=960 sink_1::height=540 sink_2::xpos=960 sink_2::ypos=270 sink_2::width=960 sink_2::height=540 ! nvvidconv ! nvoverlaysink display-id=1 a1. ! queue ! audio/x-raw ! queue ! audioconvert ! alsasink device=“hw:0,3”
Thanks in advanced
It may not be supported in running gst-launch-1.0 command. Would need other experienced users to provide suggestion.
For running a C sample, it looks possible by using appsink. Please take a look at this sample:
Starvation (?) of gstreamer threads - #12 by DaneLLL
Hi @DaneLLL ,
I found the below pipeline to stream, record, preview. But the capture only works for a single stream
gst-launch-1.0 -e v4l2src device=/dev/video2 ! queue ! video/x-raw, width=1920, height=1080, framerate=30/1 ! videorate ! video/x-raw, width=1920, height=1080, framerate=30/1 ! tee name=t1 ! nvvidconv ! queue ! nvv4l2h264enc maxperf-enable=1 bitrate=4000000 profile=4 ! queue ! h264parse ! queue ! mux. alsasrc device=“hw:4,0” ! queue ! audio/x-raw ! queue ! audioresample ! “audio/x-raw,rate=48000” ! tee name=a1 ! queue ! voaacenc ! queue ! mp4mux name=mux ! filesink location=file1.mp4 v4l2src device=/dev/video1 io-mode=2 ! queue ! image/jpeg,width=1920,height=1080,framerate=30/1 ! videorate ! image/jpeg,width=1920,height=1080,framerate=30/1 ! tee name=t2 ! nvv4l2decoder mjpeg=1 ! nvvidconv ! queue ! “video/x-raw(memory:NVMM),width=1920,height=1080,format=NV12” ! nvv4l2h264enc maxperf-enable=1 bitrate=4000000 profile=4 ! queue ! h264parse ! queue ! mux2. alsasrc device=“hw:3,0” ! queue ! audio/x-raw ! queue ! audioresample ! “audio/x-raw,rate=48000” ! tee name=a2 ! queue ! voaacenc ! queue ! mp4mux name=mux2 ! filesink location=file2.mp4 videotestsrc pattern=black ! video/x-raw,width=320,height=240 ! nvvidconv ! queue ! comp.sink_0 t1. ! queue ! nvvidconv ! queue ! “video/x-raw(memory:NVMM),width=960,height=540,format=NV12” ! queue ! comp.sink_1 t2. ! nvv4l2decoder mjpeg=1 ! nvvidconv ! queue ! “video/x-raw(memory:NVMM),width=960,height=540,format=NV12” ! queue ! comp.sink_2 nvcompositor name=comp sink_0::width=1920 sink_0::height=1080 sink_1::xpos=0 sink_1::ypos=270 sink_1::width=960 sink_1::height=540 sink_2::xpos=960 sink_2::ypos=270 sink_2::width=960 sink_2::height=540 ! tee name=t3 ! queue ! nvvidconv ! queue ! nvv4l2h264enc maxperf-enable=1 bitrate=4000000 profile=4 ! queue ! h264parse ! queue ! mux3. audiomixer name=mixer ! voaacenc ! queue ! mux3. a1. ! queue ! mixer.sink_0 a2. ! queue ! mixer.sink_1 flvmux name=mux3 ! rtmpsink location=“rtmp://localhost/live” t3. ! nvvidconv ! nvoverlaysink display-id=1 audiomixer name=mix ! queue ! audioconvert ! alsasink device=“hw:0,3” a1. ! queue ! mix.sink_0 a2. ! queue ! mix.sink_1 t1. ! videorate ! video/x-raw, width=1920, height=1080, framerate=1/1 ! jpegenc ! multifilesink location=p1.jpg t2. ! videorate ! image/jpeg,width=1920,height=1080,framerate=1/1 ! multifilesink location=p2.jpg
But the below pipeline works fine and capture images
gst-launch-1.0 -e v4l2src device=/dev/video1 io-mode=2 ! queue ! image/jpeg,width=1920,height=1080,framerate=30/1 ! videorate ! image/jpeg,width=1920,height=1080,framerate=30/1 ! videorate ! image/jpeg,width=1920,height=1080,framerate=1/1 ! multifilesink location=p2.jpg
Other video source in Italic works fine an captures images.
What is the method to solve this?
Thank You
