I have a custom board with codec max9867.
The codec codes has been modified and ported, and the asoc drive can load normally.
The playback testing is ok with setting:
amixer -c 1 cset name=‘I2S5 Mux’ ADMAIF1
however, capture testing failed with setting:
amixer -c 1 cset name=‘ADMAIF1 Mux’ I2S5
amixer -c 1 cset name=‘x Right Input Mux’ Line
amixer -c 1 cset name=‘x Left Line Switch’ on
amixer -c 1 cset name=‘x Right Line Switch’ on
I enable tracing of some of the dapm functions:
echo 0 | sudo tee /sys/kernel/debug/tracing/trace
echo 0 | sudo tee /sys/kernel/debug/tracing/events/enable
echo 1 | sudo tee /sys/kernel/debug/tracing/tracing_on
echo 1 | sudo tee /sys/kernel/debug/tracing/events/asoc/snd_soc_dapm_path/enable
echo 1 | sudo tee /sys/kernel/debug/tracing/events/asoc/snd_soc_dapm_start/enable
echo 1 | sudo tee /sys/kernel/debug/tracing/events/asoc/snd_soc_dapm_walk_done/enable
echo 1 | sudo tee /sys/kernel/debug/tracing/events/asoc/snd_soc_dapm_widget_power/enable
Then result after runing arecord -Dhw:1,0 -r 44100 -c 2 -f S16_LE <filename>.wav
is just:
root@nvidia-desktop:/sys/kernel/debug/tracing# cat trace
# tracer: nop
# entries-in-buffer/entries-written: 415/415 #P:6
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
arecord-8899 [000] .... 394.210926: snd_soc_dapm_start: card=tegra-snd-t19x-mobile
arecord-8899 [000] .... 394.211163: snd_soc_dapm_walk_done: tegra-snd-t19x-mobile: checks 2 power, 2 path, 0 neighbour
arecord-8899 [000] .... 404.355425: snd_soc_dapm_start: card=tegra-snd-t19x-mobile
arecord-8899 [000] .... 404.355511: snd_soc_dapm_path: *ADMAIF1 Transmit -> (direct) -> Capture 1
arecord-8899 [000] .... 404.355514: snd_soc_dapm_path: *ADMAIF1 Transmit -> (direct) -> ADMAIF1 Transmit-ADMAIF1 CIF Transmit
arecord-8899 [000] .... 404.355591: snd_soc_dapm_walk_done: tegra-snd-t19x-mobile: checks 2 power, 2 path, 2 neighbour
max9867.c (15.4 KB) max9867.h (2.5 KB) tegra_machine_driver_mobile.c (22.3 KB)
sound.dtsi (672 Bytes)
