Dear all,
I am now using driveworks recorder-qtgui to capture sensor data.
And the folder name is ‘dw_:…’.
Could I change the folder name before I capture the data because the file name is not compatible in ntfs/windows file system.
Thank you so much!
Dear sunwen01,
EXT4 formatted storage is prerequisite before you use recorder tool. Recorder tool automatically detects the storage path. If you use EXT4 storage, folder name should not be a problem
But our storage is ntfs.
So we want to change the name when we capture the data.
Dear sunwen01,
Unfortunately there is no provision to change folder name in tool
