Dear DPX2-developers,
I have some problems with the nvidia recorder tools.
Capturing data with 4 cameras works fine. I can use ./recorder, ./recorder-tui & ./recorder-qtgui without any errors. The data is saved on an external SSD (ext4 formatted)
Adding one more camera (to port c0 - see below rig file) to the rig json-file the data collection does not work any more.
There is my rig file and the corresponding error message using ./recorder-tui
"rig": {
"sensors": [
"name": "camera:front:120fov",
"nominalSensor2Rig": {
"quaternion": [
-0.502444,
0.507493,
-0.497444,
0.492494
"t": [
1.749,
-0.1,
1.47
"parameter": "camera-type=ar0231-rccb-bae-sf3324,csi-port=ab,camera-count=4,siblingIndex=0,format=h264,output-format=yuv,frame-record-count=1,frame-skip-count=6",
"properties": {
"Model": "ftheta",
"bw-poly": "0.0 0.000545421498827636 -1.6216719633103e-10 -4.64720492990289e-12 2.85224527762934e-16",
"cx": "960",
"cy": "604",
"height": "1208",
"width": "1920"
"protocol": "camera.gmsl",
"sensor2Rig": {
"quaternion": [
-0.502444,
0.507493,
-0.497444,
0.492494
"t": [
1.749,
-0.1,
1.47
"name": "camera:right:120fov",
"quaternion": [
-0.502444,
0.507493,
-0.497444,
0.492494
"t": [
1.749,
-0.1,
1.47
"parameter": "camera-type=ar0231-rccb-bae-sf3324,csi-port=ab,camera-count=4,siblingIndex=1,format=h264,output-format=yuv",
"properties": {
"Model": "ftheta",
"cx": "960",
"cy": "604",
"height": "1208",
"width": "1920"
"sensor2Rig": {
"quaternion": [
-0.502444,
0.507493,
-0.497444,
0.492494
"t": [
1.749,
-0.1,
1.47
"name": "camera:left:120fov",
"quaternion": [
-0.502444,
0.507493,
-0.497444,
0.492494
"t": [
1.749,
-0.1,
1.47
"parameter": "camera-type=ar0231-rccb-bae-sf3324,csi-port=ab,camera-count=4,siblingIndex=2,format=h264,output-format=yuv",
"properties": {
"Model": "ftheta",
"cx": "960",
"cy": "604",
"height": "1208",
"width": "1920"
"sensor2Rig": {
"quaternion": [
-0.502444,
0.507493,
-0.497444,
0.492494
"t": [
1.749,
-0.1,
1.47
"name": "camera:rear:120fov",
"quaternion": [
-0.502444,
0.507493,
-0.497444,
0.492494
"t": [
1.749,
-0.1,
1.47
"parameter": "camera-type=ar0231-rccb-bae-sf3324,csi-port=ab,camera-count=4,siblingIndex=3,format=h264,output-format=yuv",
"properties": {
"Model": "ftheta",
"cx": "960",
"cy": "604",
"height": "1208",
"width": "1920"
"sensor2Rig": {
"quaternion": [
-0.502444,
0.507493,
-0.497444,
0.492494
"t": [
1.749,
-0.1,
1.47
"name": "camera:front:60fov",
"quaternion": [
-0.502444,
0.507493,
-0.497444,
0.492494
"t": [
1.749,
-0.1,
1.47
"parameter": "camera-type=ar0231-rccb-bae-sf3325,csi-port=c,camera-count=1,format=h264,output-format=yuv",
"properties": {
"Model": "ftheta",
"cx": "960",
"cy": "604",
"height": "1208",
"width": "1920"
"sensor2Rig": {
"quaternion": [
-0.502444,
0.507493,
-0.497444,
0.492494
"t": [
1.749,
-0.1,
1.47
"vehicle": {
"valid": true,
"value": {
"COMMENT": "steeringCoefficient is not validated",
"axlebaseFront": 1.582,
"axlebaseRear": 1.575,
"bumperFront": 0.912,
"bumperRear": 1.109,
"centerOfMassToRearAxle": 1.564,
"frontCorneringStiffness": 30654.0,
"height": 1.473,
"inertia": 1780.8,
"length": 4.872,
"mass": 1779.4,
"rearCorneringStiffness": 36407.0,
"steeringCoefficient": 14.8,
"wheelDiameter": 0.673,
"wheelbase": 2.85,
"width": 1.852,
"widthWithMirrors": 2.121
"version": 2
Error message:
Recorder @ release: /media/nvidia/M2
4.494 MB 667.182 KB/s camera:front:120fov
140.695 KB 74.677 KB/s camera:front:60fov
366.488 KB 33.880 KB/s camera:right:120fov
5.522 MB 900.552 KB/s TOTAL
Last output: what(): DW_NOT_AVAILABLE: EncoderNvMedia: Cannot call serializeData because
cannot write to sink /media/nvidia/M2/dw_2019_09_12_07:32:01_000000_release_1576fa94-d56a-11e9-895f-00044babfec0/camera:front:120fov.h264
last error: Aborted (core dumped)
Does anyone know how to fix that problem with additional cameras?
That approach did not fix the problem. I think this is due to a older DriveWorks version
My DriveWorks version is: 5.0.10.3
Thanks in advance
best regards,
zml-koop
