Recordering tool failed on the failure of mounting resources.pak
Software Version
[V] DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[V] Linux
QNX
other
Hardware Platform
[V] other: DRIVE AGX Orin Developer Kit (940-63710-0010-200)
SDK Manager Version
[V] 1.9.1.10844
other
Host Machine Version
[V] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
Hi ,
I was trying to record data from a webcam, which could be previewed with the App “Cheese” on AGX. The camera was detected as /dev/video0 with a resolution of 960x544. The recording tools failed to launch because of the errors: no resources.pak, fail to parse rig file. I am attaching the recorder outputs(recorder_tool.log) and my rig file(usb_cam.json).
Could you provide more information about how to set up the recording tool and write a rig file for a webcam?
There is limited information in the “Recording tools” section of DriveWorks SDK Reference.
Appreciate the further information and suggestions!
recorder_tool.log (3.4 KB)
usb_cam.json (795 Bytes)
Dear @jeff.cy.chuang1,
The “no resources.pak” error can be ignored.
The supported camera sensors are at https://developer.nvidia.com/drive/ecosystem-orin#camera .
Please see if DriveWorks SDK Reference: USB Camera Capture Sample helps recording your case. Note that recording is limited to x86 only.
Hi @SivaRamaKrishnaNV ,
Thank you for the feedback.
Could you provide more information about how to decide the values of the fields in the rig file for the supported sensors, ex: the fields “parameter”, “properties”…etc. ?
BTW, could you also share the instructions of generating the binary file used in the field “car-mask”?
Or the rig file and car-mask binary will be provided by the sensor vendor?
Thank you
I hear that you have separate channel for support.
Could you please use NvBugs or contact your NVIDIA representative for guidance on support.
Thank you for the suggestion!
I will try to get the guidance from NvBugs which is just enabled this month.
