Recording camera data to disk
Is there an example within the samples to record the output from a gmsl camera to disk please?
Hi amb2,
there is a very usefull recording tool, which can be used for your task.
In addition it can record other sensor like: can, lidar, radar and gps.
You can find it under /usr/local/driveworks/tools.
There is a recording cli and a graphical one (recorder-qt).
Check the NVIDIA driveworks documentation for more details.
I hope that matches your question.
@amb2
Also, when you run the recorder the first time it makes a recorder-config.json file that you can then edit to change the path of the recorded data.
open the recorder-config.json file and edit the following line containing
"path": ".",
replace the “.” with “<your_path>”
