DRIVE OS Version: Drive OS 7.0.3
Issue Description: How do we use the Driveworks Recorder tool to record multiple output formats simultaneously?
My goal is to record to two formats (ex. LRAW+YUV) at the same time. However, the “format” parameter only takes one value as its input, and so only one format is outputted, even if the “output-format” parameter is set to “raw+processed”.
I have tried following this chart, however the chart itself seems to be incorrect; I have found that setting “output-format” to anything but “processed” or “raw+processed” gives errors, and the “format” column doesn’t seem to be the full list of supported formats.
