Hello everyone,
I’m working on the Jetson TX2 for my object detection project. I’m trying the whole time to record a video and take pictures using the CSI-onboard camera. For that I’ve found a python script that do this from the following blog : https://jkjung-avt.github.io/tx2-camera-recorder/
but it doesn’t work.
the following script is from the above blog
import sys
import argparse
import cv2
def parse_args():
# Parse input arguments
desc = 'Capture and record live camera video on Jetson TX2/TX1'
parser = argparse.ArgumentParser(description=desc)
parser.add_argument('--rtsp', dest='use_rtsp',
help='use IP CAM (remember to also set --uri)',
action='store_true')
parser.add_argument('--uri', dest='rtsp_uri',
help='RTSP URI, e.g. rtsp://192.168.1.64:554',
default=None, type=str)
parser.add_argument('--latency', dest='rtsp_latency',
help='latency in ms for RTSP [200]',
default=200, type=int)
parser.add_argument('--usb', dest='use_usb',
help='use USB webcam (remember to also set --vid)',
parser.add_argument('--vid', dest='video_dev',
help='device # of USB webcam (/dev/video?) [1]',
default=1, type=int)
parser.add_argument('--width', dest='image_width',
help='image width [640]',
default=640, type=int)
parser.add_argument('--height', dest='image_height',
help='image height [480]',
default=480, type=int)
parser.add_argument('--ts', dest='ts_file',
help='output .ts file name ["output"]',
default='output', type=str)
parser.add_argument('--fps', dest='fps',
help='fps of the output .ts video [30]',
default=30, type=int)
parser.add_argument('--rec', dest='rec_sec',
help='recording length in seconds [5]',
default=5, type=int)
parser.add_argument('--text', dest='text',
help='text overlayed on the video ["TX2 DEMO"]',
default='TX2 DEMO', type=str)
args = parser.parse_args()
return args
def open_cam_rtsp(uri, width, height, latency):
gst_str = ('rtspsrc location={} latency={} ! '
'rtph264depay ! h264parse ! omxh264dec ! '
'nvvidconv ! '
'video/x-raw, width=(int){}, height=(int){}, '
'format=(string)BGRx ! '
'videoconvert ! appsink').format(uri, latency, width, height)
return cv2.VideoCapture(gst_str, cv2.CAP_GSTREAMER)
def open_cam_usb(dev, width, height):
# We want to set width and height here, otherwise we could just do:
# return cv2.VideoCapture(dev)
gst_str = ('v4l2src device=/dev/video{} ! '
'video/x-raw, width=(int){}, height=(int){} ! '
'videoconvert ! appsink').format(dev, width, height)
def open_cam_onboard(width, height):
# On versions of L4T prior to 28.1, add 'flip-method=2' into gst_str
gst_str = ('nvarguscamerasrc ! '
'video/x-raw(memory:NVMM), '
'width=(int)2592, height=(int)1458, '
'format=(string)I420, framerate=(fraction)30/1 ! '
'nvvidconv ! '
'videoconvert ! appsink').format(width, height)
def get_video_writer(fname, fps, width, height):
gst_str = ('appsrc ! videoconvert ! omxh264enc ! mpegtsmux ! '
'filesink location={}.ts').format(fname)
return cv2.VideoWriter(gst_str, cv2.CAP_GSTREAMER, 0, fps,
(width, height))
def main():
args = parse_args()
print('Called with args:')
print(args)
print('OpenCV version: {}'.format(cv2.__version__))
if args.use_rtsp:
cap = open_cam_rtsp(args.rtsp_uri,
args.image_width,
args.image_height,
args.rtsp_latency)
elif args.use_usb:
cap = open_cam_usb(args.video_dev,
args.image_width,
args.image_height)
else: # by default, use the Jetson onboard camera
cap = open_cam_onboard(args.image_width,
args.image_height)
if not cap.isOpened():
sys.exit('Failed to open camera!')
writer = get_video_writer(args.ts_file, args.fps,
args.image_width, args.image_height)
if not writer.isOpened():
cap.release()
sys.exit('Failed to open "{}.ts"!'.format(args.ts_file))
for _ in range(args.fps * args.rec_sec): # assuming python3 here...
_, img = cap.read() # read image
if img is None:
print('No more image from camera, exiting...')
break
# put watermark on image
cv2.putText(img, args.text, (10, 60),
fontFace=cv2.FONT_HERSHEY_COMPLEX, fontScale=2.0,
color=(0, 240, 0), thickness=6, lineType=cv2.LINE_AA)
cv2.imshow('REC', img)
if cv2.waitKey(1) == 27: # ESC key: quit program
break
writer.write(img) # write current image to the ts file
writer.release()
cap.release()
if __name__ == '__main__':
main()
when i run this code it displays the following error
Downloads/Tegra-cam$ python3 tegra-cam-rec.py
Called with args:
Namespace(fps=30, image_height=480, image_width=640, rec_sec=5, rtsp_latency=200, rtsp_uri=None, text=‘TX2 DEMO’, ts_file=‘output’, use_rtsp=False, use_usb=False, video_dev=1)
OpenCV version: 4.1.2-dev
[ WARN:0] global /home/khaled/opencv/modules/videoio/src/cap_gstreamer.cpp (713) open OpenCV | GStreamer warning: Error opening bin: no element “nvcamerasrc”
[ WARN:0] global /home/khaled/opencv/modules/videoio/src/cap_gstreamer.cpp (480) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
another script returns the following error:
python3 cam_capture.py
[ WARN:0] global /home/khaled/opencv/modules/videoio/src/cap_gstreamer.cpp (1759) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module v4l2src0 reported: Internal data stream error.
[ WARN:0] global /home/khaled/opencv/modules/videoio/src/cap_gstreamer.cpp (888) open OpenCV | GStreamer warning: unable to start pipeline
select timeout
VIDIOC_DQBUF: Resource temporarily unavailable
File “cam_capture.py”, line 57, in
cv2.imshow(‘frame’,frame)
cv2.error: OpenCV(4.1.2-dev) /home/khaled/opencv/modules/highgui/src/window.cpp:376: error: (-215:Assertion failed) size.width>0 && size.height>0 in function ‘imshow’
So anyone knows how to solve it. Or if anyone has another method of how to record video and capture picture using the on-Board camera of the Jetson TX2., I would be so thankful as i started to lose some hair on this thing.
Thanks in Advance
