Recovery through UART
This is probably a quick answer but can you put a un-flashed Jetson SoM into recovery through UART?
There is a recovery pin which must be shorted to ground during power up or power reset. The UART has no ability to do this. Technically, if the unit is fully booted, then you can issue a shutdown command which brings the unit back up in recovery mode. Since your Jetson is un-flashed this won’t be possible. Also, you wouldn’t normally try to flash just a module/SoM without a carrier board…not sure if you were asking about that too.
