RectLight isProjector pattern disappears while the camera moves in RealTimePathTracing (radiance cache convergence?)
Important: Isaac Sim support
Note: For Isaac Sim support, the community is gradually transitioning from this forum to the Isaac Sim GitHub repository so that questions and issues can be tracked, searched, and resolved more efficiently in one place. Whenever possible, please create a GitHub Discussion or Issue there instead of starting a new forum topic.
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim · GitHub ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
Isaac Sim Version
6.0.1
6.0.0
5.1.0
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 24.04
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: NVIDIA GeForce RTX 3090 Ti (x2)
  • Driver Version: 580.159.04
Topic Description
RectLight used as a pattern projector (isProjector + projector:directionTexture:file) only
resolves its dot pattern while the camera is nearly stationary under RealTimePathTracing.
Once the camera moves, the dots wash out into a flat, uniform brightening. This appears to be
radiance-cache convergence rather than motion blur.
Detailed Description
I am simulating an active-stereo depth camera. A small UsdLux.RectLight acts as the dot
projector, rigidly attached next to a stereo IR camera pair on a mobile robot. The projected dots
are what the stereo matcher keys on, so the pattern has to be present in every frame, including
while the robot drives.
Projector setup:
light = UsdLux.RectLight.Define(stage, light_path)
prim = light.GetPrim()
UsdLux.ShapingAPI.Apply(prim)
light.CreateIntensityAttr(10.0)
light.CreateWidthAttr(0.005); light.CreateHeightAttr(0.005)
prim.CreateAttribute("isProjector", Sdf.ValueTypeNames.Bool).Set(True)
prim.CreateAttribute("visibleInPrimaryRay", Sdf.ValueTypeNames.Bool).Set(False)
prim.CreateAttribute("inputs:texture:file", Sdf.ValueTypeNames.Asset).Set(dot_pattern_png)
prim.CreateAttribute("projector:directionTexture:file",
                     Sdf.ValueTypeNames.Asset).Set(octahedral_direction_lut_exr)
Cameras are omni.replicator.core render products at 1280x800 with the LdrColor annotator,
ticked at 30 Hz. Scene rendermode is RealTimePathTracing (set by the environment USD).
Expected: the dot pattern is rendered every frame regardless of camera motion.
Actual: the pattern is only present when the camera is nearly still. While driving it is
replaced by a smooth, brighter wash. Energy looks conserved — on the floor the median brightness
rises from 63 to about 100 DN while the local contrast (median 9x9 standard deviation) collapses
from about 13 to 1.6.
Across one full 1200 s recording (932 IR frames), only the five frames captured before the drive
trigger carry dots:
segment frames floor dot contrast (median 9x9 std)
before the drive trigger (stationary) 5 21 to 49
driving at 0.4 m/s 927 1.6 (0.5 % of frames above 20)
Speed sweep, constant-velocity straight line, identical scene and settings:
speed floor dot contrast (median) frames with contrast > 20
0.0 m/s 27.9 63.9 %
0.05 m/s 6.4 13.9 %
0.4 m/s 1.6 0 %
While stationary the contrast keeps climbing over roughly one second of simulated time
(27.9 at 0.6 s, 39.2 at 1.2 s). That rising trend, rather than a fixed blur, is what points at an
accumulation/convergence effect. Near surfaces (a car underside 0.2 to 0.3 m away) keep their dots
even while driving; it is the far, grazing-incidence floor that loses them.
With the scene loaded, these read as follows — i.e. the obvious accumulation switches are already
off, which is why the behaviour is surprising to me:
/rtx/pathtracing/temporalAccumulation = false
/rtx/raytracing/enableAccumulation    = false
/rtx/post/motionblur/enabled          = false
/rtx/pathtracing/spp = totalSpp = clampSpp = 64
/rtx/rtpt/cached/enabled              = true
/rtx/rtpt/cached/updateSampleCount    = 1
/rtx/rtpt/cached/rcTileSize           = 5
The environment USD’s /Render prim does not override motion blur or rendermode.
Steps to Reproduce
  1. Load any scene whose rendermode is RealTimePathTracing, containing a floor seen at grazing
    incidence by a camera mounted low (about 0.12 m above the floor).
  2. Create a UsdLux.RectLight as above (isProjector, visibleInPrimaryRay=false, a dot-pattern
    texture and an octahedral direction LUT), parented next to the camera so it moves with it.
  3. Create a render product for that camera with the LdrColor annotator at 30 Hz and start the
    timeline with the camera stationary. Wait about 1 s of simulated time — the dot pattern appears
    and its local contrast keeps rising.
  4. Drive the camera forward at 0.4 m/s. Within about 0.5 s of simulated time the dots disappear and
    the surface brightens uniformly.
  5. Measure the median 9x9 local standard deviation over the lower rows of the image to see the
    collapse numerically.
Error Messages
None. Nothing is logged; the render simply loses the pattern. No texture-load failure and no
primvar warning appears for the projector or its textures.
Screenshots or Videos
Not attached here. The effect is reproduced numerically by the contrast tables above; if it would
help I can attach stationary and driving frames from the same scene.
Additional Information
What I’ve Tried
Each setting below was applied before the render products were created and confirmed applied in
the log. Floor dot contrast while driving at 0.4 m/s (stationary reference is 27.9):
change contrast
baseline (RealTimePathTracing) 1.6 to 2.0
/rtx/rendermode = RaytracedLighting 1.93
/rtx/post/aa/op 3 (DLSS) to 2 (FXAA) 2.04
/rtx/directLighting/sampledLighting/enabled = false 1.91
rendering rate 2800 Hz to 60 Hz 1.60
/rtx/pathtracing/optixDenoiser/enabled = false 1.67
/rtx/lightspeed/NRD_ReLAX/{diffuse,specular}HistoryFrames 31 to 1 1.89
/rtx/pathtracing/spp and totalSpp 64 to 1 1.90
/rtx/rtpt/cached/updateSampleCount 1 to 32 2.02
/rtx/rtpt/cached/rcTileSize 5 to 1 3.74
/rtx/rtpt/maxRoughness 0.3 to 1.0 (+ modulatingRoughnessThreshold 1.0) 2.27
/rtx/rtpt/cached/terminatePathOnFirstDiffuseHit = false 1.92
/rtx/rtpt/fireflyFilter/enabled = false 1.90
/rtx/rtpt/cfgpuCameraJitter = false 1.95
/rtx/rendermode = PathTracing 52.4 (100 % of frames above 20)
Two further observations that made me suspect the cached path:
  • With /rtx/rtpt/cached/enabled = false the dots never appear at all, not even while
    stationary (first-frame contrast drops from 12-15 to 2.2). So the pattern seems to be produced
    through the cached path rather than in spite of it.
  • PathTracing holds the pattern perfectly while driving, but at 1280x800 it produced only
    10 frames in 180 s of wall clock in this scene, so it cannot be used for continuous capture.
Questions
  1. Is this expected behaviour of the RealTimePathTracing radiance cache — that a high-frequency
    projected pattern needs roughly a second of a static camera to resolve, and that camera motion
    invalidates it faster than it converges?
  2. Is there a supported way to make a projector’s contribution bypass the cache, or to force the
    cache to converge within a single frame, while staying in a real-time render mode? The knobs I
    found (updateSampleCount, rcTileSize, terminatePathOnFirstDiffuseHit, maxRoughness) each
    moved the number slightly but never restored the pattern.
  3. Is there a recommended approach for simulating an active-stereo / structured-light projector on
    a moving platform in Isaac Sim? StructuredLightCamera in
    isaacsim.sensors.experimental.rtx looks related — is it subject to the same limitation?
Related Issues
I did not find an existing forum topic or GitHub issue describing projector patterns being lost
under camera motion. If one exists I would appreciate a pointer.
Additional Context — the workaround I settled on
In case it helps someone hitting the same wall: I stopped projecting light and started computing the
pattern instead. Each stereo IR camera already has a distance_to_image_plane annotator, so per
pixel I reconstruct the world point, transform it into the projector frame, sample the dot texture
at the resulting angle, and add gain * pattern * cos(incidence) / distance^2 to the IR image.
Both cameras use the same projector pose, so the same world point receives the same dot and the
resulting disparity is physically consistent — which is what the stereo matcher needs.
It is independent of renderer timing, costs about 10 % of the IR frame rate, and as a side effect
the dots no longer contaminate the RGB camera (a real IR projector is invisible to an IR-cut RGB
sensor, but an Isaac light has no wavelength).
That solves my use case, but it is a workaround. I would still like to understand the cache
behaviour, because anything that relies on fine projected detail on a moving platform will hit it.
Update: solved — the cause was DLSS, not the radiance cache.
Changing /rtx/post/aa/op from the default 3 (DLSS) to 4 (DLAA) brings the projected dot pattern back during camera motion. No other change: same RealTimePathTracing render mode, same RectLight isProjector + direction-texture rig, same scene, same 0.4 m/s drive.
/rtx/post/aa/op floor dot contrast while driving frames holding the pattern
3 = DLSS (default) 1.6 - 2.0 0 %
2 = FXAA 2.04 0 %
0 = none 2.04 0 %
4 = DLAA 26.51 93.1 %
Speed sweep with DLAA, same scene:
speed contrast frames above 20
0.0 m/s 33.22 90.6 %
0.4 m/s 26.51 93.1 %
0.8 m/s 27.62 92.9 %
So it is speed-independent, which the DLSS case was emphatically not.
Correction to my original post. I attributed this to the RealTimePathTracing radiance cache because disabling the cache (/rtx/rtpt/cached/enabled = false) removes the dots even while stationary, and because the contrast climbed over about a second of a static camera. Both observations are real, but the cache was not the thing destroying the pattern under motion — DLSS was. My settings sweep included aa/op 2 and 0 but not 4, which is why I missed it.
What I still do not understand, and would appreciate any insight on: why FXAA (aa/op 2) and no anti-aliasing (aa/op 0) do not recover the pattern, while DLAA does. If the problem were simply DLSS’s upscaling and temporal reuse, turning anti-aliasing off entirely should have been at least as good as DLAA. It was not — it measured the same as DLSS.
Two questions for NVIDIA:
  1. Is DLAA the recommended anti-aliasing mode for render products that must preserve high-frequency projected detail (structured light, IR dot projectors, fine normal-map detail)? The StructuredLightCamera documentation does not mention render settings at all, and this seems like a footgun worth documenting.
  2. Is StructuredLightCamera designed to work under continuous camera motion, or only with stepped rep.orchestrator.step(rt_subframes=N) capture as in the bundled example? I tried setting /omni/replicator/RTSubframes to 8 and 32 in a free-running loop that reads annotators directly, and no frames were produced at all within a 180 s window, which suggests the subframe path requires orchestrator stepping.
Why this matters beyond my case. I am simulating an active-stereo depth camera: the projected dots are the texture the stereo matcher keys on, so if they vanish under motion the depth output silently degrades to the no-projector case while still looking plausible. With DLSS the simulated depth on a vehicle body came back 26 % invalid; with DLAA it is 3.8 %, against 8.4 % measured on the real sensor. Anyone simulating structured light, projected IR patterns, or fine surface detail on a moving platform will hit this, and nothing in the docs points at the anti-aliasing mode.
Related, and possibly the same root cause: DLSS-RR suppressing high-frequency normal maps in RT 2.0 reports fine normal-map detail resolving only after several seconds of a static camera, and DLSS Ray Reconstruction persistent swimming artifact during camera motion reports an artifact identical at 1 through 16 SPP, concluding it comes from temporal reprojection rather than ray noise. Both are unanswered.
