Recurring Xid 8 (RC watchdog "GPU probably locked") on RTX PRO 6000 Blackwell under sustained compute — 595.84 and 610.43.02-open
System: RTX PRO 6000 Blackwell Workstation Edition 96 GB (GB202), Ubuntu 24.04, kernel 7.0.0-30-generic (HWE), Secure Boot on, Canonical-signed open kernel modules (GSP), currently driver 610.43.02-open (previously 595.84 — occurs on both). Persistent power limit 450 W (default 600 W — occurs at both). Host: Raptor Lake desktop platform. Second GPU in the same host: RTX 4090 (AD102), used as a control.
Signature (identical in every event):
NVRM: krcWatchdog_IMPL: RC watchdog: GPU is probably locked!  Notify Timeout Seconds: 7
NVRM: Xid (PCI:0000:01:00): 8, pid=<compute pid>, name=<llama-server|python3>, channel <varies>
The application receives CUDA error: the launch timed out and was terminated (cudaErrorLaunchTimeout). The GPU recovers in ~15 s without a reboot; no persistent damage or data corruption observed.
Occurrence pattern: 13 events since 2026-08-18 across two unrelated workloads: (a) llama.cpp long-context decode with multi-token prediction and CUDA graphs; (b) pure eager-mode PyTorch FP32 training of 4B/9B-class transformers (no CUDA graphs, no torch.compile). Under sustained saturation the rate reaches roughly one event per 20–45 minutes. The most reliable reproducer we have is (b): dense FP32 training keeping the GPU at ~100% for tens of minutes.
Isolation already done:
  • Disabling CUDA graphs (GGML_CUDA_DISABLE_GRAPHS=1) stabilized workload (a) with no recurrence since 2026-08-19 — but (b) never used CUDA graphs and still locks, so graphs look like an amplifier (submission density), not the cause.
  • Driver 595.84 → 610.43.02-open: no change in signature or rate.
  • ECC volatile + aggregate zero; row remapper zero, none pending.
  • Not thermal (≤ 87 °C observed at failure; also fails at 51 °C minutes after idle), not VRAM/context capacity (fails with > 55 GB free), not power-limit-specific (600 W and 450 W both fail).
  • Same-prompt replays fail at different decode positions after clean restarts → stochastic, not input-deterministic.
  • Control experiment: 26,912 steps (5.35 h) of the identical FP32 training stack on the RTX 4090 (AD102) in the SAME host under the SAME driver (610.43.02) produced zero events, while the GB202 locked five times the same evening under comparable sustained load. The fault isolates to the GB202 card.
  • Update 2026-09-01: a full day (~8 h of GPU-saturated windows) of sustained bf16 27B-class training and greedy decode on the same GB202 card and driver produced ZERO events. Every PyTorch run that has locked was FP32; bf16 has not reproduced it so far. Together with (a)'s CUDA-graphs sensitivity this is consistent with a submission-density / per-kernel-duration dependence.
Ask: Is this a known GSP-RM / channel-scheduling issue on GB202 under sustained high-density kernel submission? A fresh nvidia-bug-report.log.gz captured within a minute of an event is attached. We can reproduce within an hour on request, run instrumented drivers/firmware, or collect additional traces.
nvidia-bug-report-postevent-20260831T232810.gz (1.0 MB)
