Hi, I have a recursive function that I am trying to parallelize. I have a C2050 and cuda toolkit 3.1. I’m compiling using
nvcc -arch=sm_20 -o out in.cu
If I use cuda-gdb (and compile with -g -G), whenever I step into the line where the recursive function calls itself, I get the following warnings:
approximateMatchRecursive (approxRes=warning: Variable stored in multiple registers. Not supported in GDB yet. Returning garbage value.
0xfffd1000000004, approxResCount=warning: Variable stored in multiple registers. Not supported in GDB yet. Returning garbage value.
0xfffd1000000004,
maxMatches=50, query=warning: Variable stored in multiple registers. Not supported in GDB yet. Returning garbage value.
0xfffd1000000004 <Address 0xfffd1000000004 out of bounds>,
errsLeft=0, loc=3, lo=0, hi=22, rankArr=warning: Variable stored in multiple registers. Not supported in GDB yet. Returning garbage value.
0xfffd1000000004, bwArr=warning: Variable stored in multiple registers. Not supported in GDB yet. Returning garbage value.
Running the program with cuda-memcheck doesn’t report any problems. Any fixes/suggestions?
