red hat 9.0
I installed PGI complier 5.2
But, it may seem another problem.
I have a license and commend the license file to /PGI
cp license.dat /PGI
and set PATH and MANPATH.
and then,
root@ARL PGI]# pgf90 -V -c x.f
pgf90 5.2-4
Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved.
Copyright 2000-2004, STMicroelectronics, Inc. All Rights Reserved.
PGF90/any Linux/x86 5.2-4
PGF90-W-0006-Input file empty (x.f)
PGF90/any Linux/x86 5.2-4: compilation completed with warnings
PGF90/x86 Linux/x86 5.2-4
and, I didn’t change the types.h file to /usr/bin folder.
[root@ARL PGI]# cd /PGI/linux86/5.2/include
[root@ARL include]# diff ./sys/types.h /usr/include/sys/types.h
1c1,2
< /* Copyright © 1991,92,94,95,96,97,98,99 Free Software Foundation, Inc.
/* Copyright © 1991,1992,1994,1995,1996,1997,1998,1999,2000,2001,2002
5,7c6,8
< modify it under the terms of the GNU Library General Public License as
< published by the Free Software Foundation; either version 2 of the
< License, or (at your option) any later version.
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
12c13
< Library General Public License for more details.
Lesser General Public License for more details.
14,17c15,18
< You should have received a copy of the GNU Library General Public
< License along with the GNU C Library; see the file COPYING.LIB. If not,
< write to the Free Software Foundation, Inc., 59 Temple Place - Suite 330,
< Boston, MA 02111-1307, USA. */
You should have received a copy of the GNU Lesser General Public
License along with the GNU C Library; if not, write to the Free
Software Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA
02111-1307 USA. */
32a34
ifndef __u_char_defined
39a42,43
define __u_char_defined
endif
44c48
< #ifndef ino_t
#ifndef __ino_t_defined
50c54
< # define ino_t ino_t
define __ino_t_defined
52c56
< #ifdef __USE_LARGEFILE64
#if defined __USE_LARGEFILE64 && !defined __ino64_t_defined
53a58
define __ino64_t_defined
56c61
< #ifndef dev_t
#ifndef __dev_t_defined
58c63
< # define dev_t dev_t
define __dev_t_defined
61c66
< #ifndef gid_t
#ifndef __gid_t_defined
63c68
< # define gid_t gid_t
define __gid_t_defined
66c71
< #ifndef mode_t
#ifndef __mode_t_defined
68c73
< # define mode_t mode_t
define __mode_t_defined
71c76
< #ifndef nlink_t
#ifndef __nlink_t_defined
73c78
< # define nlink_t nlink_t
define __nlink_t_defined
76c81
< #ifndef uid_t
#ifndef __uid_t_defined
78c83
< # define uid_t uid_t
define __uid_t_defined
81c86
< #ifndef off_t
#ifndef __off_t_defined
87c92
< # define off_t off_t
define __off_t_defined
89c94
< #if defined __USE_LARGEFILE64 && !defined off64_t
#if defined __USE_LARGEFILE64 && !defined __off64_t_defined
91c96
< # define off64_t off64_t
define __off64_t_defined
94c99
< #ifndef pid_t
#ifndef __pid_t_defined
96c101
< # define pid_t pid_t
define __pid_t_defined
99c104
< #if defined __USE_SVID || defined __USE_XOPEN
#if (defined __USE_SVID || defined __USE_XOPEN) && !defined __id_t_defined
100a106
define __id_t_defined
103c109
< #ifndef ssize_t
#ifndef __ssize_t_defined
105c111
< # define ssize_t ssize_t
define __ssize_t_defined
108a115
ifndef __daddr_t_defined
110a118,119
define __daddr_t_defined
endif
113c122
#if (defined __USE_SVID || defined __USE_XOPEN) && !defined __key_t_defined
114a124
define __key_t_defined
120a131,132
#define __need_timer_t
#define __need_clockid_t
122a135,145
#ifdef __USE_XOPEN
ifndef __useconds_t_defined
typedef __useconds_t useconds_t;
define __useconds_t_defined
endif
ifndef __suseconds_t_defined
typedef __suseconds_t suseconds_t;
define __suseconds_t_defined
endif
#endif
135c158
< #if !defined GNUC || GNUC < 2 || GNUC_MINOR < 7
#if !__GNUC_PREREQ (2, 7)
137c160
< /* These types are defined by the ISO C 9x header <inttypes.h>. */
/* These types are defined by the ISO C99 header <inttypes.h>. */
143c166
< # if defined(GNUC) || defined(__PGI)
if __GLIBC_HAVE_LONG_LONG
152c175
199a223,227
#if defined __USE_UNIX98 && !defined __blksize_t_defined
typedef __blksize_t blksize_t;
define __blksize_t_defined
#endif
201a230
ifndef __blkcnt_t_defined
202a232,234
define __blkcnt_t_defined
endif
ifndef __fsblkcnt_t_defined
203a236,238
define __fsblkcnt_t_defined
endif
ifndef __fsfilcnt_t_defined
204a240,241
define __fsfilcnt_t_defined
endif
205a243
206a245,247
endif
207a249,251
endif
208a253,254
endif
endif
208a253,254
endif
216a263,268
/* Now add the thread types. */
#if defined __USE_POSIX199506 || defined __USE_UNIX98
include <bits/pthreadtypes.h>
#endif
[root@ARL include]# diff ./bits/types.h /usr/include/bits/types.h
49c49
< #elif defined(__GLIBC_HAVE_LONG_LONG) || defined(__PGI)
#elif defined __GLIBC_HAVE_LONG_LONG
56c56
< #if defined(__GLIBC_HAVE_LONG_LONG) || defined(__PGI)
#ifdef __GLIBC_HAVE_LONG_LONG
Does it have a problem? When I reboot the computer pgf90 doesn’t seem on computer.
for example,
root@ARL root]# pgf90 -V
-bash : pgf90: command not found
Thank you for respongind my message~
Have a nice day~
It looks like the /usr/include/bits/types.h is fine.
If you wish you can send mail to trs requesting a proper Redhat 9
$PGI/linux86/5.2/include/sys/types.h file, and we can
provide one.
The difference should be just those two lines.
% diff /usr/include/sys/types.h /usr/pgi/linux86/5.2/inlcude/sys/types.h
166c166,167
< # if __GLIBC_HAVE_LONG_LONG
/* # if __GLIBC_HAVE_LONG_LONG */
175c176,177
