I have the following Leopard Imaging carrier board plugged in:
And two cameras attached. But when I plug in the unit, the red LED beeps and chirps at me! If I take off the board the TX2 works normally.
If it makes any difference, I also have a Samsung SSD attached as well (but removing that disk had no effect).
Is this a power draw issue? If so, how do I fix? I know this configuration should work.
