It seems every time I make changes to app code, the whole .apk is regenerated and sent to device, it takes considerable time as I have a significant amount of data. Is it possible to send only .so file that is changed to the device when you hit f5 if the apk was already deployed before? Maybe there is some other workaround to speedup code tweak-> debug time? On ios it seems that xcode only sends the updated executable when you debug your app, app data is deployed only once.
Currently the whole APK must be rebuilt and redeployed to update any part of the code. We are researching other possibilities here, but cannot say anything definite as of now. You might also want to package your assets separately into the expansion files (http://developer.android.com/google/play/expansion-files.html). This ought to speed things up.
