Redis crashes the application after certain frames in deepstream-app
• Hardware Platform : Jetson Nano and TX2
• DeepStream Version :5.1
• JetPack Version : 4.5.1
• TensorRT Version: 7.1.3
• Issue Type
Im using deepstream-5.1, here Im working on deepstream-app for detecting face using primary face detector model and secondary classfiers like age, gender and emotions.
After face detection im sending the classifier details to redis.
Issue:
While running the exe after a certain frames the exe crashes and unable to send the details to redis.
But if I comment the redis part the exe works perfectly without any crash.
Redis installation steps:
KB-20513478-210921-1924-38.pdf (6.1 KB)
I have followed the above pdf document for redis installation
Hi-redis installation:
sudo apt-get install -y libhiredis-dev
The above mentioned installations were done for redis
Attached code for reference:
 * Copyright (c) 2018-2020, NVIDIA CORPORATION. All rights reserved.
 * Permission is hereby granted, free of charge, to any person obtaining a
 * copy of this software and associated documentation files (the "Software"),
 * to deal in the Software without restriction, including without limitation
 * the rights to use, copy, modify, merge, publish, distribute, sublicense,
 * and/or sell copies of the Software, and to permit persons to whom the
 * Software is furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
 * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
 * DEALINGS IN THE SOFTWARE.
#include <gst/gst.h>
#include <string.h>
#include <math.h>
#include <stdlib.h>
#include <cuda_runtime_api.h>
#include <time.h>
#include <unistd.h>
#include <stdio.h>
#include <glib.h>
#include <sys/time.h>
#include "deepstream_app.h"
// For JSON Header
#include "parson.h"
//Redis
#include <hiredis/hiredis.h>
#define MAX 100
#include "gstnvdsmeta.h"
#define PGIE_CLASS_ID_FACE 0
#define MAX_DISPLAY_LEN 64
static guint batch_num = 0;
static guint demux_batch_num = 0;
GST_DEBUG_CATEGORY_EXTERN (NVDS_APP);
GQuark _dsmeta_quark;
#define CEIL(a,b) ((a + b - 1) / b)
 * @brief  Add the (nvmsgconv->nvmsgbroker) sink-bin to the
 *         overall DS pipeline (if any configured) and link the same to
 *         common_elements.tee (This tee connects
 *         the common analytics path to Tiler/display-sink and
 *         to configured broker sink if any)
 *         NOTE: This API shall return TRUE if there are no
 *         broker sinks to add to pipeline
 * @param  appCtx [IN]
 * @return TRUE if succussful; FALSE otherwise
static gboolean add_and_link_broker_sink (AppCtx * appCtx);
 * @brief  Checks if there are any [sink] groups
 *         configured for source_id=provided source_id
 *         NOTE: source_id key and this API is valid only when we
 *         disable [tiler] and thus use demuxer for individual
 *         stream out
 * @param  config [IN] The DS Pipeline configuration struct
 * @param  source_id [IN] Source ID for which a specific [sink]
 *         group is searched for
static gboolean is_sink_available_for_source_id(NvDsConfig *config, guint source_id);
 * callback function to receive messages from components
 * in the pipeline.
char* camID = "FaceCam";
char* EBDID = "BOX001";
char *trackID;
char *timestamp;
char uniqueTrackID[1000];
gint frame_number = 0;
//Object Structure
struct ObjectList
  struct timeval start_time;
  struct timeval end_time;
  int meta;
  char UID[1000]; //Change the buffer size accoring to the machine
  char age_group_label[50];
  char gender_label[50];
  char emotion_label[50];
  struct ObjectList *next;
struct ObjectList *current_objects = NULL;
struct ObjectList *current_objects_current = NULL;
struct ObjectList * get_object(struct ObjectList *current_objects, int new_id) {
    for(struct ObjectList* tmp=current_objects; tmp != NULL; tmp=tmp->next) {
        if(tmp->meta == new_id) {
            return tmp;
    return NULL;
// //Check and set end_time
void set_data_for_objects_no_longer_in_current_frame(int current_frame_obj_ids[], struct ObjectList *current_objects, int n, struct timeval ct) {
        int curr_id = tmp->meta;
        bool found = false;
        for(int i=0; i < n; i++) {
            if(current_frame_obj_ids[i] == curr_id) {
                found = true;
                // printf("Found:%d\n", found);
        //FaceLoss
        if(!found ) {
            // tmp->has_set_end_time = true;
            // printf("Loss Id: %d\n",tmp->meta);
            // Unique TrackID
            // if (asprintf(&trackID, "%d", tmp->meta ) == -1) {
            // perror("asprintf");
            // else if(asprintf(&timestamp, "%d", tmp->start_time.tv_sec ) == -1){
            // else {
            // strcat(strcpy(uniqueTrackID, timestamp),"_");
            // strcat(uniqueTrackID,camID);
            // strcat(uniqueTrackID,"_");
            // strcat(uniqueTrackID,EBDID);
            // strcat(uniqueTrackID, trackID);
            // printf("TRACKID : %s\n", uniqueTrackID);
            // free(trackID);
            // free(timestamp);
            // JSON Value after Face Loss
            JSON_Value *root_value = json_value_init_object();
            JSON_Object *root_object = json_value_get_object(root_value);
            char *obj_json = NULL;
            json_object_set_string(root_object, "EBDID", EBDID);
            json_object_set_number(root_object, "FID", tmp->meta);
            json_object_set_string(root_object, "Gender", tmp->gender_label);
            json_object_set_string(root_object, "Age", tmp->age_group_label);
            json_object_set_string(root_object, "Emotion", tmp->emotion_label);
            json_object_set_number(root_object, "Atttime", tmp->end_time.tv_sec - tmp->start_time.tv_sec);
            json_object_set_string(root_object, "CamID", camID);
            json_object_set_number(root_object, "Start_Time", tmp->start_time.tv_sec);
            json_object_set_number(root_object, "End_Time", tmp->end_time.tv_sec);
            // json_object_set_string(root_object, "TrackID", uniqueTrackID);
            json_object_set_string(root_object, "TrackID", tmp->UID);
            obj_json = json_serialize_to_string_pretty(root_value);
            // puts(obj_json);
            // printf("JSON:%s\n", obj_json);
            // Sending Json to Redis
            redisContext *context;
            redisReply *reply;
            context = redisConnect("127.0.0.1", 6379);
            // if (!context) {
            // fprintf(stderr, "Error:  Can't connect to Redis after face loss\n");
            // else{
            //   fprintf(stdout, "Success: Redis Connected after face loss\n");
            char key[MAX];
				    sprintf(key, "analytics_%s",tmp->UID);
            reply = redisCommand(context, "SET %s %s", key, obj_json);
            json_free_serialized_string(obj_json);
            json_value_free(root_value);
void print_current_objects(struct ObjectList *current_objects) {
        printf("Object id: %d\n", tmp->meta);
        printf("UniqueTrackID:  %s\n",tmp->UID);
        printf("Start time: %lu\n", tmp->start_time.tv_sec);
        printf("End time: %lu\n", tmp->end_time.tv_sec);
        printf("Age : %s\n",tmp->age_group_label);
        printf("Emotion : %s\n",tmp->emotion_label);
        printf("Gender : %s\n",tmp->gender_label);
        int Atttime = tmp->end_time.tv_sec - tmp->start_time.tv_sec;
        printf("Attention Time : %u\n\n",Atttime);
static gboolean
bus_callback (GstBus * bus, GstMessage * message, gpointer data)
  AppCtx *appCtx = (AppCtx *) data;
  GST_CAT_DEBUG (NVDS_APP,
      "Received message on bus: source %s, msg_type %s",
      GST_MESSAGE_SRC_NAME (message), GST_MESSAGE_TYPE_NAME (message));
  switch (GST_MESSAGE_TYPE (message)) {
    case GST_MESSAGE_INFO:{
      GError *error = NULL;
      gchar *debuginfo = NULL;
      gst_message_parse_info (message, &error, &debuginfo);
      g_printerr ("INFO from %s: %s\n",
          GST_OBJECT_NAME (message->src), error->message);
      if (debuginfo) {
        g_printerr ("Debug info: %s\n", debuginfo);
      g_error_free (error);
      g_free (debuginfo);
      break;
    case GST_MESSAGE_WARNING:{
      gst_message_parse_warning (message, &error, &debuginfo);
      g_printerr ("WARNING from %s: %s\n",
      if (debuginfo) {
      g_free (debuginfo);
      break;
    case GST_MESSAGE_ERROR:{
      guint i = 0;
      gst_message_parse_error (message, &error, &debuginfo);
      g_printerr ("ERROR from %s: %s\n",
      if (debuginfo) {
      NvDsSrcParentBin *bin = &appCtx->pipeline.multi_src_bin;
      GstElement *msg_src_elem = (GstElement *) GST_MESSAGE_SRC (message);
      gboolean bin_found = FALSE;
      /* Find the source bin which generated the error. */
      while (msg_src_elem && !bin_found) {
        for (i = 0; i < bin->num_bins && !bin_found; i++) {
          if (bin->sub_bins[i].src_elem == msg_src_elem ||
                  bin->sub_bins[i].bin == msg_src_elem) {
            bin_found = TRUE;
            break;
        msg_src_elem = GST_ELEMENT_PARENT (msg_src_elem);
      if ((i != bin->num_bins) &&
          (appCtx->config.multi_source_config[0].type == NV_DS_SOURCE_RTSP)) {
        // Error from one of RTSP source.
        NvDsSrcBin *subBin = &bin->sub_bins[i];
        if (!subBin->reconfiguring ||
            g_strrstr(debuginfo, "500 (Internal Server Error)")) {
          subBin->reconfiguring = TRUE;
          g_timeout_add (0, reset_source_pipeline, subBin);
        g_free (debuginfo);
        return TRUE;
      if (appCtx->config.multi_source_config[0].type == NV_DS_SOURCE_CAMERA_V4L2) {
        if (g_strrstr(debuginfo, "reason not-negotiated (-4)")) {
          NVGSTDS_INFO_MSG_V ("incorrect camera parameters provided, please provide supported resolution and frame rate\n");
        if (g_strrstr(debuginfo, "Buffer pool activation failed")) {
          NVGSTDS_INFO_MSG_V ("usb bandwidth might be saturated\n");
      g_free (debuginfo);
      appCtx->return_value = -1;
      appCtx->quit = TRUE;
      break;
    case GST_MESSAGE_STATE_CHANGED:{
      GstState oldstate, newstate;
      gst_message_parse_state_changed (message, &oldstate, &newstate, NULL);
      if (GST_ELEMENT (GST_MESSAGE_SRC (message)) == appCtx->pipeline.pipeline) {
        switch (newstate) {
          case GST_STATE_PLAYING:
            NVGSTDS_INFO_MSG_V ("Pipeline running\n");
            GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS (GST_BIN (appCtx->
                    pipeline.pipeline), GST_DEBUG_GRAPH_SHOW_ALL,
                "ds-app-playing");
            break;
          case GST_STATE_PAUSED:
            if (oldstate == GST_STATE_PLAYING) {
              NVGSTDS_INFO_MSG_V ("Pipeline paused\n");
            break;
          case GST_STATE_READY:
            GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS (GST_BIN (appCtx->pipeline.
                    pipeline), GST_DEBUG_GRAPH_SHOW_ALL, "ds-app-ready");
            if (oldstate == GST_STATE_NULL) {
              NVGSTDS_INFO_MSG_V ("Pipeline ready\n");
            } else {
              NVGSTDS_INFO_MSG_V ("Pipeline stopped\n");
            break;
          case GST_STATE_NULL:
            g_mutex_lock (&appCtx->app_lock);
            g_cond_broadcast (&appCtx->app_cond);
            g_mutex_unlock (&appCtx->app_lock);
            break;
          default:
            break;
      break;
    case GST_MESSAGE_EOS:{
       * In normal scenario, this would use g_main_loop_quit() to exit the
       * loop and release the resources. Since this application might be
       * running multiple pipelines through configuration files, it should wait
       * till all pipelines are done.
      NVGSTDS_INFO_MSG_V ("Received EOS. Exiting ...\n");
      return FALSE;
      break;
    default:
      break;
  return TRUE;
 * Function to dump bounding box data in kitti format. For this to work,
 * property "gie-kitti-output-dir" must be set in configuration file.
 * Data of different sources and frames is dumped in separate file.
static void
write_kitti_output (AppCtx * appCtx, NvDsBatchMeta * batch_meta)
  gchar bbox_file[1024] = { 0 };
  FILE *bbox_params_dump_file = NULL;
  if (!appCtx->config.bbox_dir_path)
    return;
  for (NvDsMetaList * l_frame = batch_meta->frame_meta_list; l_frame != NULL;
      l_frame = l_frame->next) {
    NvDsFrameMeta *frame_meta = l_frame->data;
    guint stream_id = frame_meta->pad_index;
    g_snprintf (bbox_file, sizeof (bbox_file) - 1,
        "%s/%02u_%03u_%06lu.txt", appCtx->config.bbox_dir_path,
        appCtx->index, stream_id, (gulong) frame_meta->frame_num);
    bbox_params_dump_file = fopen (bbox_file, "w");
    if (!bbox_params_dump_file)
      continue;
    for (NvDsMetaList * l_obj = frame_meta->obj_meta_list; l_obj != NULL;
        l_obj = l_obj->next) {
      NvDsObjectMeta *obj = (NvDsObjectMeta *) l_obj->data;
      float left = obj->rect_params.left;
      float top = obj->rect_params.top;
      float right = left + obj->rect_params.width;
      float bottom = top + obj->rect_params.height;
      // Here confidence stores detection confidence, since dump gie output
      // is before tracker plugin
      float confidence = obj->confidence;
      fprintf (bbox_params_dump_file,
          "%s 0.0 0 0.0 %f %f %f %f 0.0 0.0 0.0 0.0 0.0 0.0 0.0 %f\n",
          obj->obj_label, left, top, right, bottom, confidence);
    fclose (bbox_params_dump_file);
 * Function to dump past frame objs in kitti format.
static void
write_kitti_past_track_output (AppCtx * appCtx, NvDsBatchMeta * batch_meta)
  if (!appCtx->config.kitti_track_dir_path)
    return;
  // dump past frame tracked objects appending current frame objects
    NvDsPastFrameObjBatch *pPastFrameObjBatch = NULL;
    NvDsUserMetaList *bmeta_list = NULL;
    NvDsUserMeta *user_meta = NULL;
    for(bmeta_list=batch_meta->batch_user_meta_list; bmeta_list!=NULL; bmeta_list=bmeta_list->next){
      user_meta = (NvDsUserMeta *)bmeta_list->data;
      if(user_meta && user_meta->base_meta.meta_type==NVDS_TRACKER_PAST_FRAME_META){
        pPastFrameObjBatch = (NvDsPastFrameObjBatch *) (user_meta->user_meta_data);
        for (uint si=0; si < pPastFrameObjBatch->numFilled; si++){
          NvDsPastFrameObjStream *objStream = (pPastFrameObjBatch->list) + si;
          guint stream_id = (guint)(objStream->streamID);
          for (uint li=0; li<objStream->numFilled; li++){
            NvDsPastFrameObjList *objList = (objStream->list) + li;
            for (uint oi=0; oi<objList->numObj; oi++) {
              NvDsPastFrameObj *obj = (objList->list) + oi;
                "%s/%02u_%03u_%06lu.txt", appCtx->config.kitti_track_dir_path,
                appCtx->index, stream_id, (gulong) obj->frameNum);
              float left = obj->tBbox.left;
              float right = left + obj->tBbox.width;
              float top = obj->tBbox.top;
              float bottom = top + obj->tBbox.height;
              // Past frame object confidence given by tracker
              bbox_params_dump_file = fopen (bbox_file, "a");
              if (!bbox_params_dump_file){
                continue;
              fprintf(bbox_params_dump_file,
                "%s %lu 0.0 0 0.0 %f %f %f %f 0.0 0.0 0.0 0.0 0.0 0.0 0.0 %f\n",
                objList->objLabel, objList->uniqueId, left, top, right, bottom, confidence);
 * Function to dump bounding box data in kitti format with tracking ID added.
 * For this to work, property "kitti-track-output-dir" must be set in configuration file.
static void
write_kitti_track_output (AppCtx * appCtx, NvDsBatchMeta * batch_meta)
    return;
      continue;
      float left = obj->tracker_bbox_info.org_bbox_coords.left;
      float top = obj->tracker_bbox_info.org_bbox_coords.top;
      float right = left + obj->tracker_bbox_info.org_bbox_coords.width;
      float bottom = top + obj->tracker_bbox_info.org_bbox_coords.height;
      // Here confidence stores tracker confidence value for tracker output
      float confidence = obj->tracker_confidence;
      guint64 id = obj->object_id;
          obj->obj_label, id, left, top, right, bottom, confidence);
static gint
component_id_compare_func (gconstpointer a, gconstpointer b)
  NvDsClassifierMeta *cmetaa = (NvDsClassifierMeta *) a;
  NvDsClassifierMeta *cmetab = (NvDsClassifierMeta *) b;
  if (cmetaa->unique_component_id < cmetab->unique_component_id)
    return -1;
  if (cmetaa->unique_component_id > cmetab->unique_component_id)
    return 1;
  return 0;
 * Function to process the attached metadata. This is just for demonstration
 * and can be removed if not required.
 * Here it demonstrates to use bounding boxes of different color and size for
 * different type / class of objects.
 * It also demonstrates how to join the different labels(PGIE + SGIEs)
 * of an object to form a single string.
static void
process_meta (AppCtx * appCtx, NvDsBatchMeta * batch_meta)
  // For single source always display text either with demuxer or with tiler
  if (!appCtx->config.tiled_display_config.enable ||
      appCtx->config.num_source_sub_bins == 1) {
    appCtx->show_bbox_text = 1;
      gint class_index = obj->class_id;
      NvDsGieConfig *gie_config = NULL;
      gchar *str_ins_pos = NULL;
      if (obj->unique_component_id ==
          (gint) appCtx->config.primary_gie_config.unique_id) {
        gie_config = &appCtx->config.primary_gie_config;
      } else {
        for (gint i = 0; i < (gint) appCtx->config.num_secondary_gie_sub_bins;
            i++) {
          gie_config = &appCtx->config.secondary_gie_sub_bin_config[i];
          if (obj->unique_component_id == (gint) gie_config->unique_id) {
            break;
          gie_config = NULL;
      g_free (obj->text_params.display_text);
      obj->text_params.display_text = NULL;
      if (gie_config != NULL) {
        if (g_hash_table_contains (gie_config->bbox_border_color_table,
                class_index + (gchar *) NULL)) {
          obj->rect_params.border_color =
              *((NvOSD_ColorParams *)
              g_hash_table_lookup (gie_config->bbox_border_color_table,
                  class_index + (gchar *) NULL));
        } else {
          obj->rect_params.border_color = gie_config->bbox_border_color;
        obj->rect_params.border_width = appCtx->config.osd_config.border_width;
        if (g_hash_table_contains (gie_config->bbox_bg_color_table,
          obj->rect_params.has_bg_color = 1;
          obj->rect_params.bg_color =
              g_hash_table_lookup (gie_config->bbox_bg_color_table,
        } else {
          obj->rect_params.has_bg_color = 0;
      if (!appCtx->show_bbox_text)
        continue;
      obj->text_params.x_offset = obj->rect_params.left;
      obj->text_params.y_offset = obj->rect_params.top - 30;
      obj->text_params.font_params.font_color =
          appCtx->config.osd_config.text_color;
      obj->text_params.font_params.font_size =
          appCtx->config.osd_config.text_size;
      obj->text_params.font_params.font_name = appCtx->config.osd_config.font;
      if (appCtx->config.osd_config.text_has_bg) {
        obj->text_params.set_bg_clr = 1;
        obj->text_params.text_bg_clr = appCtx->config.osd_config.text_bg_color;
      obj->text_params.display_text = g_malloc (128);
      obj->text_params.display_text[0] = '\0';
      str_ins_pos = obj->text_params.display_text;
      if (obj->obj_label[0] != '\0')
        sprintf (str_ins_pos, "%s", obj->obj_label);
      str_ins_pos += strlen (str_ins_pos);
      if (obj->object_id != UNTRACKED_OBJECT_ID) {
        /** object_id is a 64-bit sequential value;
         * but considering the display aesthetic,
         * trimming to lower 32-bits */
        if (appCtx->config.tracker_config.display_tracking_id) {
          guint64 const LOW_32_MASK = 0x00000000FFFFFFFF;
          sprintf (str_ins_pos, " %lu", (obj->object_id & LOW_32_MASK));
      obj->classifier_meta_list =
          g_list_sort (obj->classifier_meta_list, component_id_compare_func);
      for (NvDsMetaList * l_class = obj->classifier_meta_list; l_class != NULL;
          l_class = l_class->next) {
        NvDsClassifierMeta *cmeta = (NvDsClassifierMeta *) l_class->data;
        for (NvDsMetaList * l_label = cmeta->label_info_list; l_label != NULL;
            l_label = l_label->next) {
          NvDsLabelInfo *label = (NvDsLabelInfo *) l_label->data;
          if (label->pResult_label) {
            sprintf (str_ins_pos, " %s", label->pResult_label);
          } else if (label->result_label[0] != '\0') {
            sprintf (str_ins_pos, " %s", label->result_label);
 * Function which processes the inferred buffer and its metadata.
 * It also gives opportunity to attach application specific
 * metadata (e.g. clock, analytics output etc.).
static void
process_buffer (GstBuffer * buf, AppCtx * appCtx, guint index)
  NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
  if (!batch_meta) {
    NVGSTDS_WARN_MSG_V ("Batch meta not found for buffer %p", buf);
    return;
  process_meta (appCtx, batch_meta);
  //NvDsInstanceData *data = &appCtx->instance_data[index];
  //guint i;
  //  data->frame_num++;
  /* Opportunity to modify the processed metadata or do analytics based on
   * type of object e.g. maintaining count of particular type of car.
  if (appCtx->all_bbox_generated_cb) {
    appCtx->all_bbox_generated_cb (appCtx, buf, batch_meta, index);
  //data->bbox_list_size = 0;
   * callback to attach application specific additional metadata.
  if (appCtx->overlay_graphics_cb) {
    appCtx->overlay_graphics_cb (appCtx, buf, batch_meta, index);
 * Buffer probe function to get the results of primary infer.
 * Here it demonstrates the use by dumping bounding box coordinates in
 * kitti format.
static GstPadProbeReturn
gie_primary_processing_done_buf_prob (GstPad * pad, GstPadProbeInfo * info,
    gpointer u_data)
  GstBuffer *buf = (GstBuffer *) info->data;
  AppCtx *appCtx = (AppCtx *) u_data;
  if (!batch_meta) {
    return GST_PAD_PROBE_OK;
  write_kitti_output (appCtx, batch_meta);
 * Probe function to get results after all inferences(Primary + Secondary)
 * are done. This will be just before OSD or sink (in case OSD is disabled).
gie_processing_done_buf_prob (GstPad * pad, GstPadProbeInfo * info,
    gpointer u_data)
  NvDsInstanceBin *bin = (NvDsInstanceBin *) u_data;
  guint index = bin->index;
  AppCtx *appCtx = bin->appCtx;
  if (gst_buffer_is_writable (buf))
    process_buffer (buf, appCtx, index);
 * Buffer probe function after tracker.
analytics_done_buf_prob (GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
  guint num_rects = 0;
  NvDsObjectMeta *obj_meta = NULL;
  guint face_count = 0;
  guint id;
  NvDsMetaList * l_frame = NULL;
  NvDsMetaList * l_obj = NULL;
  NvDsDisplayMeta *display_meta = NULL;
  NvDsClassifierMetaList *l_classifier = NULL;
  NvDsClassifierMeta *class_meta = NULL;
  NvDsLabelInfoList *l_label = NULL;
  NvDsLabelInfo *label_info = NULL;
  int current_device = -1;
  cudaGetDevice(&current_device);
  struct cudaDeviceProp prop;
  cudaGetDeviceProperties(&prop, current_device);
  struct timeval current_time;
  for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
      NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
      int offset = 0;
      int obj_ids[50];
      int current_pos = 0;
      for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
          obj_meta = (NvDsObjectMeta *) (l_obj->data);
          if (obj_meta->class_id == PGIE_CLASS_ID_FACE) {
              face_count++;
              num_rects++;
// *** GCE-DS-BLOCK ***
              id = obj_meta->object_id;
              obj_ids[current_pos] = id;
              current_pos++;
              // int cc = 0;
              char age_group[50]={""};
              char gender[50]={""};
              char emotion[50]={""};
              for(l_classifier = obj_meta->classifier_meta_list; l_classifier != NULL;
              l_classifier = l_classifier->next) {
                class_meta = (NvDsClassifierMeta *)(l_classifier->data);
                //UID for Age,Gender,Emotion
                int uniqueClassID = class_meta->unique_component_id;
                for(l_label = class_meta->label_info_list; l_label != NULL;
                  label_info = (NvDsLabelInfo *) (l_label->data);
                  // g_print ("******************FRAME START********************************* \n");
                  // g_print ("FrameNo:%d \n",frame_number);
                  // g_print("%d", id);
                  // g_print("-------");
                  // g_print ("%s\n", label_info->result_label);
                  if (uniqueClassID==3)
                      strcpy(age_group,label_info->result_label);
                  else if (uniqueClassID==4)
                    strcpy(emotion,label_info->result_label);
                  else if (uniqueClassID==2)
                    strcpy(gender,label_info->result_label);
              // cc ++;
              struct ObjectList * res = get_object(current_objects, id);
              gettimeofday(&current_time, NULL);
              if(!res) {
                  // Object doesn't exist
                  struct ObjectList *new_node = (struct ObjectList *) malloc(sizeof(struct ObjectList));
                  //StartTime and EndTime for frames
                  new_node->start_time = current_time;
                  new_node->end_time = current_time;
                  // new_node->has_set_end_time = false;
                  new_node->meta = id;
                  // Unique TrackID
                  if (asprintf(&trackID, "%d", obj_meta->object_id ) == -1) {
                  perror("asprintf");
                  else if(asprintf(&timestamp, "%d", new_node->start_time) == -1){
                    perror("asprintf");
                  else {
                  strcpy(new_node->UID, uniqueTrackID);
                  free(trackID);
                  free(timestamp);
                  strcpy(new_node->age_group_label, age_group);
                  strcpy(new_node->emotion_label, emotion);
                  strcpy(new_node->gender_label, gender);
                  if(current_objects_current == NULL) {
                      current_objects_current = new_node;
                      current_objects = current_objects_current;
                  } else {
                      current_objects_current->next = new_node;
                      current_objects_current = current_objects_current->next;
              } else {
                res->end_time= current_time;
                strcpy(res->age_group_label, age_group);
                strcpy(res->emotion_label, emotion);
                strcpy(res->gender_label, gender);
      struct timeval ct = current_time;
      set_data_for_objects_no_longer_in_current_frame(obj_ids, current_objects, current_pos, ct);
      display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
      NvOSD_TextParams *txt_params  = &display_meta->text_params[0];
      display_meta->num_labels = 1;
      txt_params->display_text = g_malloc0 (MAX_DISPLAY_LEN);
      offset = snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN, "Face = %d \n", face_count);
      offset = snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN, "Frame Number = %d ", frame_number);
      /* Now set the offsets where the string should appear */
      txt_params->x_offset = 10;
      txt_params->y_offset = 12;
      /* Font , font-color and font-size */
      txt_params->font_params.font_name = "Serif";
      txt_params->font_params.font_size = 10;
      txt_params->font_params.font_color.red = 1.0;
      txt_params->font_params.font_color.green = 1.0;
      txt_params->font_params.font_color.blue = 1.0;
      txt_params->font_params.font_color.alpha = 1.0;
      /* Text background color */
      txt_params->set_bg_clr = 1;
      txt_params->text_bg_clr.red = 0.0;
      txt_params->text_bg_clr.green = 0.0;
      txt_params->text_bg_clr.blue = 0.0;
      txt_params->text_bg_clr.alpha = 1.0;
      nvds_add_display_meta_to_frame(frame_meta, display_meta);
  if (!batch_meta) {
   * Output KITTI labels with tracking ID if configured to do so.
  write_kitti_track_output(appCtx, batch_meta);
  if (appCtx->config.tracker_config.enable_past_frame)
      write_kitti_past_track_output (appCtx, batch_meta);
  if (appCtx->bbox_generated_post_analytics_cb)
    appCtx->bbox_generated_post_analytics_cb (appCtx, buf, batch_meta, index);
  // print_current_objects(current_objects);
  // g_print ("Frame Number = %d Number of objects = %d "
  //         "Face Count = %d Timestamp = %d \n",
  //         frame_number, num_rects, face_count, (int)time(NULL));
  // g_print ("**********************FRAME END***************************** \n");
  frame_number++;
latency_measurement_buf_prob(GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
  guint i = 0, num_sources_in_batch = 0;
  if(nvds_enable_latency_measurement)
    NvDsFrameLatencyInfo *latency_info = NULL;
    g_mutex_lock (&appCtx->latency_lock);
    latency_info = appCtx->latency_info;
    g_print("\n************BATCH-NUM = %d**************\n",batch_num);
    num_sources_in_batch = nvds_measure_buffer_latency(buf, latency_info);
    for(i = 0; i < num_sources_in_batch; i++)
      g_print("Source id = %d Frame_num = %d Frame latency = %lf (ms) \n",
          latency_info[i].source_id,
          latency_info[i].frame_num,
          latency_info[i].latency);
    g_mutex_unlock (&appCtx->latency_lock);
    batch_num++;
demux_latency_measurement_buf_prob(GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
    g_print("\n************DEMUX BATCH-NUM = %d**************\n",demux_batch_num);
    demux_batch_num++;
static gboolean
  NvDsConfig *config = &appCtx->config;
  /** Only first instance_bin broker sink
   * employed as there's only one analytics path for N sources
   * NOTE: There shall be only one [sink] group
   * with type=6 (NV_DS_SINK_MSG_CONV_BROKER)
   * a) Multiple of them does not make sense as we have only
   * one analytics pipe generating the data for broker sink
   * b) If Multiple broker sinks are configured by the user
   * in config file, only the first in the order of
   * appearance will be considered
   * and others shall be ignored
   * c) Ideally it should be documented (or obvious) that:
   * multiple [sink] groups with type=6 (NV_DS_SINK_MSG_CONV_BROKER)
   * is invalid
  NvDsInstanceBin *instance_bin = &appCtx->pipeline.instance_bins[0];
  NvDsPipeline *pipeline = &appCtx->pipeline;
  for (guint i = 0; i < config->num_sink_sub_bins; i++) {
    if(config->sink_bin_sub_bin_config[i].type == NV_DS_SINK_MSG_CONV_BROKER)
      if(!pipeline->common_elements.tee) {
         NVGSTDS_ERR_MSG_V ("%s failed; broker added without analytics; check config file\n", __func__);
         return FALSE;
      /** add the broker sink bin to pipeline */
      if(!gst_bin_add (GST_BIN (pipeline->pipeline), instance_bin->sink_bin.sub_bins[i].bin)) {
        return FALSE;
      /** link the broker sink bin to the common_elements tee
       * (The tee after nvinfer -> tracker (optional) -> sgies (optional) block) */
      if (!link_element_to_tee_src_pad (pipeline->common_elements.tee, instance_bin->sink_bin.sub_bins[i].bin)) {
        return FALSE;
  return TRUE;
static gboolean
create_demux_pipeline (AppCtx * appCtx, guint index)
  gboolean ret = FALSE;
  NvDsInstanceBin *instance_bin = &appCtx->pipeline.demux_instance_bins[index];
  GstElement *last_elem;
  gchar elem_name[32];
  instance_bin->index = index;
  instance_bin->appCtx = appCtx;
  g_snprintf (elem_name, 32, "processing_demux_bin_%d", index);
  instance_bin->bin = gst_bin_new (elem_name);
  if (!create_demux_sink_bin (config->num_sink_sub_bins,
        config->sink_bin_sub_bin_config, &instance_bin->demux_sink_bin,
        config->sink_bin_sub_bin_config[index].source_id)) {
    goto done;
  gst_bin_add (GST_BIN (instance_bin->bin), instance_bin->demux_sink_bin.bin);
  last_elem = instance_bin->demux_sink_bin.bin;
  if (config->osd_config.enable) {
    if (!create_osd_bin (&config->osd_config, &instance_bin->osd_bin)) {
      goto done;
    gst_bin_add (GST_BIN (instance_bin->bin), instance_bin->osd_bin.bin);
    NVGSTDS_LINK_ELEMENT (instance_bin->osd_bin.bin, last_elem);
    last_elem = instance_bin->osd_bin.bin;
  NVGSTDS_BIN_ADD_GHOST_PAD (instance_bin->bin, last_elem, "sink");
    NVGSTDS_ELEM_ADD_PROBE (instance_bin->all_bbox_buffer_probe_id,
        instance_bin->osd_bin.nvosd, "sink",
        gie_processing_done_buf_prob, GST_PAD_PROBE_TYPE_BUFFER, instance_bin);
  } else {
        instance_bin->demux_sink_bin.bin, "sink",
  ret = TRUE;
done:
  if (!ret) {
    NVGSTDS_ERR_MSG_V ("%s failed", __func__);
  return ret;
 * Function to add components to pipeline which are dependent on number
 * of streams. These components work on single buffer. If tiling is being
 * used then single instance will be created otherwise < N > such instances
 * will be created for < N > streams
static gboolean
create_processing_instance (AppCtx * appCtx, guint index)
  NvDsInstanceBin *instance_bin = &appCtx->pipeline.instance_bins[index];
  g_snprintf (elem_name, 32, "processing_bin_%d", index);
  if (!create_sink_bin (config->num_sink_sub_bins,
        config->sink_bin_sub_bin_config, &instance_bin->sink_bin, index)) {
    goto done;
  gst_bin_add (GST_BIN (instance_bin->bin), instance_bin->sink_bin.bin);
  last_elem = instance_bin->sink_bin.bin;
      goto done;
  } else {
        instance_bin->sink_bin.bin, "sink",
  ret = TRUE;
done:
  if (!ret) {
  return ret;
 * Function to create common elements(Primary infer, tracker, secondary infer)
 * of the pipeline. These components operate on muxed data from all the
 * streams. So they are independent of number of streams in the pipeline.
static gboolean
create_common_elements (NvDsConfig * config, NvDsPipeline * pipeline,
    GstElement ** sink_elem, GstElement ** src_elem,
    bbox_generated_callback bbox_generated_post_analytics_cb)
  *sink_elem = *src_elem = NULL;
  if (config->primary_gie_config.enable) {
    if (config->num_secondary_gie_sub_bins > 0) {
      if (!create_secondary_gie_bin (config->num_secondary_gie_sub_bins,
              config->primary_gie_config.unique_id,
              config->secondary_gie_sub_bin_config,
              &pipeline->common_elements.secondary_gie_bin)) {
        goto done;
          pipeline->common_elements.secondary_gie_bin.bin);
      if (!*src_elem) {
        *src_elem = pipeline->common_elements.secondary_gie_bin.bin;
      if (*sink_elem) {
        NVGSTDS_LINK_ELEMENT (pipeline->common_elements.secondary_gie_bin.bin,
            *sink_elem);
      *sink_elem = pipeline->common_elements.secondary_gie_bin.bin;
  if (config->dsanalytics_config.enable) {
    // Create dsanalytics element bin and set properties
    if (!create_dsanalytics_bin (&config->dsanalytics_config,
            &pipeline->common_elements.dsanalytics_bin)) {
      g_print ("creating dsanalytics bin failed\n");
      goto done;
    // Add dsanalytics bin to instance bin
    gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->common_elements.dsanalytics_bin.bin);
      if (!*src_elem) {
        *src_elem = pipeline->common_elements.dsanalytics_bin.bin;
      if (*sink_elem) {
        NVGSTDS_LINK_ELEMENT (pipeline->common_elements.dsanalytics_bin.bin,
            *sink_elem);
    // Set this bin as the last element
    *sink_elem = pipeline->common_elements.dsanalytics_bin.bin;
  if (config->tracker_config.enable) {
    if (!create_tracking_bin (&config->tracker_config,
            &pipeline->common_elements.tracker_bin)) {
      g_print ("creating tracker bin failed\n");
      goto done;
        pipeline->common_elements.tracker_bin.bin);
    if (!*src_elem) {
      *src_elem = pipeline->common_elements.tracker_bin.bin;
    if (*sink_elem) {
      NVGSTDS_LINK_ELEMENT (pipeline->common_elements.tracker_bin.bin,
          *sink_elem);
    *sink_elem = pipeline->common_elements.tracker_bin.bin;
    if (!create_primary_gie_bin (&config->primary_gie_config,
            &pipeline->common_elements.primary_gie_bin)) {
      goto done;
        pipeline->common_elements.primary_gie_bin.bin);
    if (*sink_elem) {
      NVGSTDS_LINK_ELEMENT (pipeline->common_elements.primary_gie_bin.bin,
          *sink_elem);
    *sink_elem = pipeline->common_elements.primary_gie_bin.bin;
    if (!*src_elem) {
      *src_elem = pipeline->common_elements.primary_gie_bin.bin;
    NVGSTDS_ELEM_ADD_PROBE (pipeline->common_elements.
        primary_bbox_buffer_probe_id,
        pipeline->common_elements.primary_gie_bin.bin, "src",
        gie_primary_processing_done_buf_prob, GST_PAD_PROBE_TYPE_BUFFER,
        pipeline->common_elements.appCtx);
  if(*src_elem) {
          *src_elem, "src",
          analytics_done_buf_prob, GST_PAD_PROBE_TYPE_BUFFER,
          &pipeline->common_elements);
    /* Add common message converter */
    if (config->msg_conv_config.enable) {
      NvDsSinkMsgConvBrokerConfig *convConfig = &config->msg_conv_config;
      pipeline->common_elements.msg_conv = gst_element_factory_make (NVDS_ELEM_MSG_CONV, "common_msg_conv");
      if (!pipeline->common_elements.msg_conv) {
        NVGSTDS_ERR_MSG_V ("Failed to create element 'common_msg_conv'");
        goto done;
      g_object_set (G_OBJECT (pipeline->common_elements.msg_conv),
                    "config", convConfig->config_file_path,
                    "msg2p-lib", (convConfig->conv_msg2p_lib ? convConfig->conv_msg2p_lib : "null"),
                    "payload-type", convConfig->conv_payload_type,
                    "comp-id", convConfig->conv_comp_id,
                    "debug-payload-dir", convConfig->debug_payload_dir,
                    "multiple-payloads", convConfig->multiple_payloads, NULL);
                   pipeline->common_elements.msg_conv);
      NVGSTDS_LINK_ELEMENT (*src_elem, pipeline->common_elements.msg_conv);
      *src_elem = pipeline->common_elements.msg_conv;
    pipeline->common_elements.tee = gst_element_factory_make (NVDS_ELEM_TEE, "common_analytics_tee");
    if (!pipeline->common_elements.tee) {
      NVGSTDS_ERR_MSG_V ("Failed to create element 'common_analytics_tee'");
      goto done;
          pipeline->common_elements.tee);
    NVGSTDS_LINK_ELEMENT (*src_elem, pipeline->common_elements.tee);
    *src_elem = pipeline->common_elements.tee;
  ret = TRUE;
done:
  return ret;
static gboolean is_sink_available_for_source_id(NvDsConfig *config, guint source_id) {
  for (guint j = 0; j < config->num_sink_sub_bins; j++) {
    if (config->sink_bin_sub_bin_config[j].enable &&
        config->sink_bin_sub_bin_config[j].source_id == source_id &&
        config->sink_bin_sub_bin_config[j].link_to_demux == FALSE) {
      return TRUE;
  return FALSE;
 * Main function to create the pipeline.
gboolean
create_pipeline (AppCtx * appCtx,
    bbox_generated_callback bbox_generated_post_analytics_cb,
    bbox_generated_callback all_bbox_generated_cb, perf_callback perf_cb,
    overlay_graphics_callback overlay_graphics_cb)
  GstBus *bus;
  GstElement *tmp_elem1;
  GstElement *tmp_elem2;
  guint i;
  GstPad *fps_pad;
  gulong latency_probe_id;
  _dsmeta_quark = g_quark_from_static_string (NVDS_META_STRING);
  appCtx->all_bbox_generated_cb = all_bbox_generated_cb;
  appCtx->bbox_generated_post_analytics_cb = bbox_generated_post_analytics_cb;
  appCtx->overlay_graphics_cb = overlay_graphics_cb;
  if (config->osd_config.num_out_buffers < 8) {
    config->osd_config.num_out_buffers = 8;
  pipeline->pipeline = gst_pipeline_new ("pipeline");
  if (!pipeline->pipeline) {
    NVGSTDS_ERR_MSG_V ("Failed to create pipeline");
    goto done;
  bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline->pipeline));
  pipeline->bus_id = gst_bus_add_watch (bus, bus_callback, appCtx);
  gst_object_unref (bus);
  if (config->file_loop) {
    /* Let each source bin know it needs to loop. */
    guint i;
    for (i = 0; i < config->num_source_sub_bins; i++)
        config->multi_source_config[i].loop = TRUE;
    NvDsSinkSubBinConfig *sink_config = &config->sink_bin_sub_bin_config[i];
    switch (sink_config->type) {
      case NV_DS_SINK_FAKE:
      case NV_DS_SINK_RENDER_EGL:
      case NV_DS_SINK_RENDER_OVERLAY:
        /* Set the "qos" property of sink, if not explicitly specified in the
           config. */
        if (!sink_config->render_config.qos_value_specified) {
          sink_config->render_config.qos = FALSE;
      default:
        break;
   * Add muxer and < N > source components to the pipeline based
   * on the settings in configuration file.
  if (!create_multi_source_bin (config->num_source_sub_bins,
          config->multi_source_config, &pipeline->multi_src_bin))
    goto done;
  gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->multi_src_bin.bin);
  if (config->streammux_config.is_parsed){
    if(!set_streammux_properties (&config->streammux_config,
        pipeline->multi_src_bin.streammux)){
         NVGSTDS_WARN_MSG_V("Failed to set streammux properties");
  if(appCtx->latency_info == NULL)
    appCtx->latency_info = (NvDsFrameLatencyInfo *)
      calloc(1, config->streammux_config.batch_size *
          sizeof(NvDsFrameLatencyInfo));
  /** a tee after the tiler which shall be connected to sink(s) */
  pipeline->tiler_tee = gst_element_factory_make (NVDS_ELEM_TEE, "tiler_tee");
  if (!pipeline->tiler_tee) {
    NVGSTDS_ERR_MSG_V ("Failed to create element 'tiler_tee'");
    goto done;
  gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->tiler_tee);
  /** Tiler + Demux in Parallel Use-Case */
  if (config->tiled_display_config.enable == NV_DS_TILED_DISPLAY_ENABLE_WITH_PARALLEL_DEMUX)
    pipeline->demuxer =
        gst_element_factory_make (NVDS_ELEM_STREAM_DEMUX, "demuxer");
    if (!pipeline->demuxer) {
      NVGSTDS_ERR_MSG_V ("Failed to create element 'demuxer'");
      goto done;
    gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->demuxer);
    /** NOTE:
     * demux output is supported for only one source
     * If multiple [sink] groups are configured with
     * link_to_demux=1, only the first [sink]
     * shall be constructed for all occurences of
     * [sink] groups with link_to_demux=1
      gchar pad_name[16];
      GstPad *demux_src_pad;
      i = 0;
      if (!create_demux_pipeline (appCtx, i)) {
        goto done;
      for (i=0; i < config->num_sink_sub_bins; i++)
        if (config->sink_bin_sub_bin_config[i].link_to_demux == TRUE)
          g_snprintf (pad_name, 16, "src_%02d", config->sink_bin_sub_bin_config[i].source_id);
          break;
      if (i >= config->num_sink_sub_bins)
        g_print ("\n\nError : sink for demux (use link-to-demux-only property) is not provided in the config file\n\n");
        goto done;
      i = 0;
          pipeline->demux_instance_bins[i].bin);
      demux_src_pad = gst_element_get_request_pad (pipeline->demuxer, pad_name);
      NVGSTDS_LINK_ELEMENT_FULL (pipeline->demuxer, pad_name,
          pipeline->demux_instance_bins[i].bin, "sink");
      gst_object_unref (demux_src_pad);
      NVGSTDS_ELEM_ADD_PROBE(latency_probe_id,
          appCtx->pipeline.demux_instance_bins[i].demux_sink_bin.bin,
          "sink",
          demux_latency_measurement_buf_prob, GST_PAD_PROBE_TYPE_BUFFER,
          appCtx);
      latency_probe_id = latency_probe_id;
    last_elem = pipeline->demuxer;
    link_element_to_tee_src_pad (pipeline->tiler_tee, last_elem);
    last_elem = pipeline->tiler_tee;
  if (config->tiled_display_config.enable) {
    /* Tiler will generate a single composited buffer for all sources. So need
     * to create only one processing instance. */
    if (!create_processing_instance (appCtx, 0)) {
      goto done;
    // create and add tiling component to pipeline.
    if (config->tiled_display_config.columns *
        config->tiled_display_config.rows < config->num_source_sub_bins) {
      if (config->tiled_display_config.columns == 0) {
            (guint) (sqrt (config->num_source_sub_bins) + 0.5);
      config->tiled_display_config.rows =
          (guint) ceil (1.0 * config->num_source_sub_bins /
          config->tiled_display_config.columns);
      NVGSTDS_WARN_MSG_V
          ("Num of Tiles less than number of sources, readjusting to "
          "%u rows, %u columns", config->tiled_display_config.rows,
    gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->instance_bins[0].bin);
    last_elem = pipeline->instance_bins[0].bin;
    if (!create_tiled_display_bin (&config->tiled_display_config,
            &pipeline->tiled_display_bin)) {
      goto done;
    gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->tiled_display_bin.bin);
    NVGSTDS_LINK_ELEMENT (pipeline->tiled_display_bin.bin, last_elem);
    last_elem = pipeline->tiled_display_bin.bin;
    link_element_to_tee_src_pad (pipeline->tiler_tee, pipeline->tiled_display_bin.bin);
    NVGSTDS_ELEM_ADD_PROBE (latency_probe_id,
      pipeline->instance_bins->sink_bin.sub_bins[0].sink, "sink",
      appCtx);
  else
     * Create demuxer only if tiled display is disabled.
    pipeline->demuxer =
      goto done;
      gchar pad_name[16];
      /* Check if any sink has been configured to render/encode output for
       * source index `i`. The processing instance for that source will be
       * created only if atleast one sink has been configured as such.
      if (!is_sink_available_for_source_id(config, i))
        continue;
      if (!create_processing_instance(appCtx, i))
        goto done;
      gst_bin_add(GST_BIN(pipeline->pipeline),
                  pipeline->instance_bins[i].bin);
      g_snprintf(pad_name, 16, "src_%02d", i);
      demux_src_pad = gst_element_get_request_pad(pipeline->demuxer, pad_name);
      NVGSTDS_LINK_ELEMENT_FULL(pipeline->demuxer, pad_name,
                                pipeline->instance_bins[i].bin, "sink");
      gst_object_unref(demux_src_pad);
      for (int k = 0; k < MAX_SINK_BINS;k++) {
        if(pipeline->instance_bins[i].sink_bin.sub_bins[k].sink){
              pipeline->instance_bins[i].sink_bin.sub_bins[k].sink, "sink",
              appCtx);
          break;
  if (config->tiled_display_config.enable == NV_DS_TILED_DISPLAY_DISABLE) {
    fps_pad = gst_element_get_static_pad (pipeline->demuxer, "sink");
  else {
    fps_pad = gst_element_get_static_pad (pipeline->tiled_display_bin.bin, "sink");
  pipeline->common_elements.appCtx = appCtx;
  // Decide where in the pipeline the element should be added and add only if
  // enabled
  if (config->dsexample_config.enable) {
    // Create dsexample element bin and set properties
    if (!create_dsexample_bin (&config->dsexample_config,
            &pipeline->dsexample_bin)) {
      goto done;
    // Add dsexample bin to instance bin
    gst_bin_add (GST_BIN (pipeline->pipeline), pipeline->dsexample_bin.bin);
    // Link this bin to the last element in the bin
    NVGSTDS_LINK_ELEMENT (pipeline->dsexample_bin.bin, last_elem);
    last_elem = pipeline->dsexample_bin.bin;
  // create and add common components to pipeline.
  if (!create_common_elements (config, pipeline, &tmp_elem1, &tmp_elem2,
          bbox_generated_post_analytics_cb)) {
    goto done;
  if(!add_and_link_broker_sink(appCtx)) {
    goto done;
  if (tmp_elem2) {
    NVGSTDS_LINK_ELEMENT (tmp_elem2, last_elem);
    last_elem = tmp_elem1;
  NVGSTDS_LINK_ELEMENT (pipeline->multi_src_bin.bin, last_elem);
  // enable performance measurement and add call back function to receive
  // performance data.
  if (config->enable_perf_measurement) {
    appCtx->perf_struct.context = appCtx;
    enable_perf_measurement (&appCtx->perf_struct, fps_pad,
        pipeline->multi_src_bin.num_bins,
        config->perf_measurement_interval_sec,
        config->multi_source_config[0].dewarper_config.num_surfaces_per_frame,
        perf_cb);
  if (config->num_message_consumers) {
    for (i = 0; i < config->num_message_consumers; i++) {
      appCtx->c2d_ctx[i] = start_cloud_to_device_messaging (
                                &config->message_consumer_config[i], NULL,
                                &appCtx->pipeline.multi_src_bin);
      if (appCtx->c2d_ctx[i] == NULL) {
        NVGSTDS_ERR_MSG_V ("Failed to create message consumer");
        goto done;
  GST_DEBUG_BIN_TO_DOT_FILE_WITH_TS (GST_BIN (appCtx->pipeline.pipeline),
      GST_DEBUG_GRAPH_SHOW_ALL, "ds-app-null");
  g_mutex_init (&appCtx->app_lock);
  g_cond_init (&appCtx->app_cond);
  g_mutex_init (&appCtx->latency_lock);
  ret = TRUE;
done:
  if (!ret) {
  return ret;
 * Function to destroy pipeline and release the resources, probes etc.
void
destroy_pipeline (AppCtx * appCtx)
  gint64 end_time;
  guint i;
  GstBus *bus = NULL;
  end_time = g_get_monotonic_time () + G_TIME_SPAN_SECOND;
  if (!appCtx)
    return;
  if (appCtx->pipeline.demuxer) {
    gst_pad_send_event (gst_element_get_static_pad (appCtx->pipeline.demuxer,
            "sink"), gst_event_new_eos ());
  } else if (appCtx->pipeline.instance_bins[0].sink_bin.bin) {
            pipeline.instance_bins[0].sink_bin.bin, "sink"),
  g_usleep (100000);
  if (appCtx->pipeline.pipeline) {
    destroy_smart_record_bin (&appCtx->pipeline.multi_src_bin);
    bus = gst_pipeline_get_bus (GST_PIPELINE (appCtx->pipeline.pipeline));
    while (TRUE) {
      GstMessage *message = gst_bus_pop (bus);
      if (message == NULL)
        break;
      else if (GST_MESSAGE_TYPE (message) == GST_MESSAGE_ERROR)
        bus_callback (bus, message, appCtx);
      else
        gst_message_unref (message);
    gst_element_set_state (appCtx->pipeline.pipeline, GST_STATE_NULL);
  g_cond_wait_until (&appCtx->app_cond, &appCtx->app_lock, end_time);
  for (i = 0; i < appCtx->config.num_source_sub_bins; i++) {
    NvDsInstanceBin *bin = &appCtx->pipeline.instance_bins[i];
      NVGSTDS_ELEM_REMOVE_PROBE (bin->all_bbox_buffer_probe_id,
          bin->osd_bin.nvosd, "sink");
    } else {
          bin->sink_bin.bin, "sink");
      NVGSTDS_ELEM_REMOVE_PROBE (bin->primary_bbox_buffer_probe_id,
          bin->primary_gie_bin.bin, "src");
    free(appCtx->latency_info);
    appCtx->latency_info = NULL;
  destroy_sink_bin ();
  g_mutex_clear(&appCtx->latency_lock);
    gst_bus_remove_watch (bus);
    gst_object_unref (appCtx->pipeline.pipeline);
      if (appCtx->c2d_ctx[i])
        stop_cloud_to_device_messaging (appCtx->c2d_ctx[i]);
gboolean
pause_pipeline (AppCtx * appCtx)
  GstState cur;
  GstState pending;
  GstStateChangeReturn ret;
  GstClockTime timeout = 5 * GST_SECOND / 1000;
  ret =
      gst_element_get_state (appCtx->pipeline.pipeline, &cur, &pending,
      timeout);
  if (ret == GST_STATE_CHANGE_ASYNC) {
    return FALSE;
  if (cur == GST_STATE_PAUSED) {
    return TRUE;
  } else if (cur == GST_STATE_PLAYING) {
    gst_element_set_state (appCtx->pipeline.pipeline, GST_STATE_PAUSED);
        GST_CLOCK_TIME_NONE);
    pause_perf_measurement (&appCtx->perf_struct);
    return TRUE;
  } else {
    return FALSE;
gboolean
resume_pipeline (AppCtx * appCtx)
  GstState cur;
  GstState pending;
  ret =
      timeout);
    return FALSE;
    return TRUE;
  } else if (cur == GST_STATE_PAUSED) {
    gst_element_set_state (appCtx->pipeline.pipeline, GST_STATE_PLAYING);
    resume_perf_measurement (&appCtx->perf_struct);
    return TRUE;
  } else {
    return FALSE;
Note:
In this function im using the redis code as mentioned below:
            redisReply *reply;
            char key[MAX];
				    // sprintf(key, "analytics_%s",uniqueTrackID);
Anyone help me to solve this issue.
Thank you
Hi @RajeshMuthuswamy ,
Sorry! Is Redis DeepStream related?
@mchi Redis I installed externally as in the pdf
The following is the redis code which I have used in the deepstream-app
            redisReply *reply;
            char key[MAX];
void set_data_for_objects_no_longer_in_current_frame(int current_frame_obj_ids, struct ObjectList *current_objects, int n, struct timeval ct) {
redisReply *reply;
        char key[MAX];
We have redis broker functions implemented, you just need to specify the connection string in configuration and anything metadata you want to send, customized and encapsulated into NvDsEventMsgMeta.
the message conversion will filter metadata based on NVDS_EVENT_MSG_META type, and generates the “DeepStream Schema” payload in Json format. generated payload is attached as NVDS_META_PAYLOAD type metadata to the buffer.
“nvmsgbroker” plugin extracts NVDS_META_PAYLOAD type of metadata from the buffer and sends that payload to the server using APIs in nvmsgbroker C library.
