I trained an SSD model in TLT and got an mAP during evaluation on test set of 70.0. When the same model was converted to an engine and loaded into DeepStream, the output was evaluated again using the COCO API to get AP@0.5 (same as that done in TLT) the mAP was 41.0.
Can you help out with figuring out what the problem is?
Here are the TLT specifications for SSD training:
ssd_config {
aspect_ratios_global: "[1.0, 2.0, 0.5, 3.0, 1.0/3.0]"
scales: "[0.05, 0.1, 0.25, 0.4, 0.55, 0.7, 0.85]"
two_boxes_for_ar1: true
clip_boxes: false
loss_loc_weight: 0.8
focal_loss_alpha: 0.25
focal_loss_gamma: 2.0
variances: "[0.1, 0.1, 0.2, 0.2]"
arch: "resnet18"
freeze_bn: false
freeze_blocks: 0
training_config {
batch_size_per_gpu: 16
num_epochs: 220
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-5
max_learning_rate: 2e-2
soft_start: 0.1
annealing: 0.3
optimizer {
adam {
epsilon: 1e-08
beta1: 0.9
beta2: 0.999
regularizer {
type: L1
weight: 3.00000002618e-09
eval_config {
validation_period_during_training: 10
average_precision_mode: SAMPLE
batch_size: 32
matching_iou_threshold: 0.5
nms_config {
confidence_threshold: 0.01
clustering_iou_threshold: 0.6
top_k: 200
augmentation_config {
preprocessing {
output_image_width: 960
output_image_height: 540
output_image_channel: 3
crop_right: 960
crop_bottom: 540
min_bbox_width: 1.0
min_bbox_height: 1.0
spatial_augmentation {
hflip_probability: 0.5
vflip_probability: 0.0
zoom_min: 0.7
zoom_max: 1.8
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.20000000298
contrast_scale_max: 0.10000000149
contrast_center: 0.5
dataset_config {
data_sources: {
tfrecords_path: "/dfs/SSD_Benchmarking/tlt-experiments/ssd_tdcafe/tfrecords/tdcafe_trainval*"
image_directory_path: "/dfs/SSD_Benchmarking/tlt-experiments/data"
image_extension: "jpg"
target_class_mapping {
key: "person"
value: "person"
validation_fold: 0
And the DeepStream configuration:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=1
gie-kitti-output-dir=output
[tiled-display]
enable=0
rows=1
columns=1
width=960
height=540
gpu-id=2
nvbuf-memory-type=0
[source0]
enable=1
type=2
uri=file:/dfs/fahad/coco_annotator/coco-annotator/datasets/MRCNN_TestSet_h264.mp4
gpu-id=2
cudadec-memtype=0
[streammux]
gpu-id=2
batch-size=1
batched-push-timeout=-1
width=1920
height=1080
nvbuf-memory-type=0
[sink0]
enable=1
type=1
output-file=file:/software/out_tuned_mrcnn.mp4
container=1
codec=3
sync=0
gpu-id=2
source-id=0
[osd]
enable=0
gpu-id=2
border-width=3
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=2
batch-size=1
interval=0
model-engine-file=/software/tlt-experiments/ssd_tdcafe/engines_pruned_0.4_retrained_x4/ssd_resnet18_epoch_170_FP32.etlt_b1_fp32.engine
labelfile-path=/root/deepstream_sdk_v4.0.2_x86_64/sources/objectDetector_SSD/labels.txt
config-file=/root/deepstream_sdk_v4.0.2_x86_64/sources/objectDetector_SSD/pgie_ssd_uff_config_test.txt
nvbuf-memory-type=0
[tracker]
enable=0
tracker-width=320
tracker-height=180
ll-config-file=/root/deepstream_sdk_v4.0.2_x86_64/samples/configs/deepstream-app/iou_config.txt
ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_iou.so
gpu-id=2
enable-batch-process=1
[tests]
file-loop=0
And the primary GIE configuration:
[property]
net-scale-factor=1.0
offsets=103.939;116.779;123.68
model-color-format=1
tlt-encoded-model=/software/tlt-experiments/ssd_tdcafe/engines_pruned_0.4_retrained_x4/ssd_resnet18_epoch_170_FP32.etlt
tlt-model-key=OHBuNWlvczJzMG41bmVuN2dscnZkdWk1NnQ6YjkyZGI1ZjQtM2EwYi00OWQxLTg1MzItODRkNGU0ZGU5ODU3
uff-input-dims=3;540;960;0
uff-input-blob-name=Input
network-mode=0
num-detected-classes=1
gie-unique-id=1
is-classifier=0
output-blob-names=NMS
parse-bbox-func-name=NvDsInferParseCustomSSDUff
custom-lib-path=/root/deepstream_sdk_v4.0.2_x86_64/sources/objectDetector_SSD/nvdsinfer_customparser_ssd_uff/libnvds_infercustomparser_ssd_uff.so
[class-attrs-all]
threshold=0.3
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
