• Hardware Platform : dGPU (Nvidia A30) • DeepStream Version 6.0 • TensorRT Version 8.0 • NVIDIA GPU Driver Version : 470 • Issue Type: question
I am using nvv4l2decoder to parse the input H.264 buffers coming from 32 channels in Deepstream 6.0. The input stream frame rate is ~30FPS per channel, but nvv4l2decoder can only decode up to ~26FPS per channel. Setting drop-frame-rate to a value other than 0 does not help because dropping happens only after fully decoding all of the frames in the input.
Futhermore, skipping frames before they enter nvv4l2decoder does not help either, because removing P frames from H.264 affects other decoded frames in the stream.
I have tried setting the parameters of the decoder such as num_extra_surfaces without any improvement in the decoder speed.
I do not have access to the provider of input stream and cannot change the frame rate. Is there any way to tackle the decoder bottleneck ?
Hi @bolat.ashim I am experiencing exactly your same issue. As of now, I haven’t found any solution besides using the CPU to decode a number of video streams, but the FPS on CPU is extremely low. I think we would need to find a way to drop packages before sending them to the decoder. That being said, decoding a frames usually requires data from previous and/or next frames, so I am not sure data can be dropped. For sure, dropping random data would result in corrupted images. I am desperately looking for a solution, but I am not sure there could be one. Please, let me know if you find anything.
