Reduction breaking in 15.3?
I have 14.7 and 15.3 installed on OSX. The following works in the former, but not in the later version. In 14.7, the result is “test ok” while in 15.3 it will print “sum c failed: 0.000000 ; expected: 1966080”.
Update: I just checked the same on linux with 14.7 and 15.1 - same result: 14.7 works, 15.1 sets the sum to 0.
module example
contains
 subroutine data_region(a, b, c, d, sum_c, sum_d)
  use openacc
  implicit none
  real, intent(in) :: a(256, 256, 10), b(256, 256, 10)
  real, intent(out) :: c(256, 256, 10), d(256, 256, 10)
  real, intent(out) :: sum_c, sum_d
!$acc enter data copyin(a), copyin(c), copyin(b), copyin(d)
  call run(a, b, c, d)
  call reduce_to_sum (c, sum_c)
  call reduce_to_sum (d, sum_d)
!$acc exit data delete(a), copyout(c), delete(b), copyout(d)
end subroutine
 subroutine run(a, b, c, d)
  use openacc
  implicit none
  call add (a, b, c)
  call mult (a, b, d)
end subroutine
 subroutine add(a, b, c)
  use openacc
  implicit none
  integer :: z
  integer(4) :: y, x
!$acc kernels
!$acc loop independent vector(16)
  do y=1,256
   do x=1,256
!$acc loop seq
    do z=1,10
     c(x, y, z)= a(x, y, z)+ b(x, y, z)
    end do
   end do
  end do
!$acc end kernels
end subroutine
 subroutine mult(a, b, d)
  use openacc
  implicit none
  real, intent(out) :: d(256, 256, 10)
  integer :: z
  integer(4) :: y, x
!$acc kernels
  do y=1,256
   do x=1,256
!$acc loop seq
    do z=1,10
     d(x, y, z)= a(x, y, z)* b(x, y, z)
    end do
   end do
  end do
!$acc end kernels
end subroutine
 subroutine reduce_to_sum(a, result)
  use openacc
  implicit none
  real, intent(out) :: result
  integer :: z
  integer(4) :: y, x
  result = 0.0d0
!$acc kernels
!$acc loop independent vector(16) reduction(+: result)
  do y=1,256
   do x=1,256
!$acc loop seq
    do z=1,10
     result = result + a(x, y, z)
    end do
   end do
  end do
!$acc end kernels
end subroutine
end module example
program main
use example
implicit none
real, dimension(256, 256, 10) :: a, b, c, d
real :: sum_c, sum_d, expected_sum
integer :: x, y, z
integer :: fail_x, fail_y, fail_z
logical test
a(:,:,:) = 1.0d0
b(:,:,:) = 2.0d0
c(:,:,:) = 0.0d0
d(:,:,:) = 0.0d0
test = .TRUE.
call data_region(a, b, c, d, sum_c, sum_d)
write(6,*) "calculation complete"
expected_sum = 3.0d0 * 256 * 256 * 10
if ( abs(sum_c - expected_sum) > 1E-5 ) then
write(6,*) "sum c failed: ", sum_c, "; expected: ", expected_sum
stop 2
end if
expected_sum = 2.0d0 * 256 * 256 * 10
if ( abs(sum_d - expected_sum) > 1E-5 ) then
write(6,*) "sum d failed: ", sum_d, "; expected: ", expected_sum
stop 2
end if
do y=1,256
 do x=1,256
  do z=1,10
   if (test .EQ. .TRUE. .AND. c(x, y, z) /= 3.0d0) then
   test = .FALSE.
   fail_x = x
   fail_y = y
   fail_z = z
   end if
   if (test .EQ. .TRUE. .AND. d(x, y, z) /= 2.0d0) then
   test = .FALSE.
   fail_x = x
   fail_y = y
   fail_z = z
   end if
  end do
 end do
end do
if (test .EQ. .TRUE.) then
write(6,*) "test ok"
else
write(6,*) "test failed"
write(6,*) "fails at", fail_x, fail_y, fail_z, "C:", c(fail_x, fail_y, fail_z), "D:", d(fail_x, fail_y, fail_z)
stop 2
end if
stop
end program main
[/code]
Hi Michel,
The example “works” in 14.7 only because we think there’s a dependency on “result” given it has intent out. Hence only a scalar kernel is being generated.
reduce_to_sum:
     89, Generating present_or_copyin(a(:,:,:))
         Generating Tesla code
     91, Accelerator restriction: scalar variable live-out from loop: result
     93, Accelerator restriction: scalar variable live-out from loop: result
     95, Loop is parallelizable
         Accelerator kernel generated
Once we fixed the dependency issue and generate the parallel kernel, it exposes the problem with the reduction. I can recreate the problem in 14.7 if I use a local variable instead of the argument.
I have added a problem report (TPR#21474) and sent it to engineering for further investigation. The work around is to remove the “reduction” clause and instead let the compiler discover the reduction. It seems to create the correct results in this case.
Mat
% cat test_032715.1.f90
module example
 contains
   use openacc
   implicit none
 end subroutine
   use openacc
   implicit none
   call add (a, b, c)
   call mult (a, b, d)
 end subroutine
   use openacc
   implicit none
   integer :: z
   integer(4) :: y, x
 !$acc kernels
   do y=1,256
    do x=1,256
 !$acc loop seq
     do z=1,10
     end do
    end do
   end do
 !$acc end kernels
 end subroutine
   use openacc
   implicit none
   integer :: z
   integer(4) :: y, x
 !$acc kernels
   do y=1,256
    do x=1,256
 !$acc loop seq
     do z=1,10
     end do
    end do
   end do
 !$acc end kernels
 end subroutine
   use openacc
   implicit none
   integer :: z
   integer(4) :: y, x
   result = 0.0d0
 !$acc kernels
   do y=1,256
    do x=1,256
 !$acc loop seq
     do z=1,10
     end do
    end do
   end do
 !$acc end kernels
 end subroutine
 end module example
 program main
 use example
 implicit none
 integer :: x, y, z
 logical test
 a(:,:,:) = 1.0d0
 b(:,:,:) = 2.0d0
 c(:,:,:) = 0.0d0
 d(:,:,:) = 0.0d0
 test = .TRUE.
 stop 2
 end if
 stop 2
 end if
 do y=1,256
  do x=1,256
   do z=1,10
    test = .FALSE.
    fail_x = x
    fail_y = y
    fail_z = z
    end if
    test = .FALSE.
    fail_x = x
    fail_y = y
    fail_z = z
    end if
   end do
  end do
 end do
 else
 stop 2
 end if
 stop
 end program main
% pgfortran -acc -Minfo=accel test_032715.1.f90; a.out
data_region:
     11, Generating enter data copyin(d(:,:,:),b(:,:,:),c(:,:,:),a(:,:,:))
     17, Generating exit data copyout(d(:,:,:),b(:,:,:),c(:,:,:),a(:,:,:))
add:
     41, Generating copyout(c(:,:,:))
         Generating copyin(a(:,:,:),b(:,:,:))
     43, Loop is parallelizable
     45, Loop is parallelizable
     47, Loop is parallelizable
         43, !$acc loop gang, vector(16) ! blockidx%y threadidx%y
         45, !$acc loop gang, vector(16) ! blockidx%x threadidx%x
mult:
     64, Generating copyout(d(:,:,:))
     66, Loop is parallelizable
     68, Loop is parallelizable
     70, Loop is parallelizable
         66, !$acc loop gang, vector(16) ! blockidx%y threadidx%y
         68, !$acc loop gang, vector(16) ! blockidx%x threadidx%x
reduce_to_sum:
     89, Generating copyin(a(:,:,:))
     91, Loop is parallelizable
     93, Loop is parallelizable
         91, !$acc loop gang, vector(16) ! blockidx%y threadidx%y
         93, !$acc loop gang, vector(16) ! blockidx%x threadidx%x
         96, Sum reduction generated for result
 test ok
Warning: ieee_inexact is signaling
FORTRAN STOP
Thanks Mat! Once again your workaround works.
TP#21474 is resolved with PGI 20.1
