Reduction of number of landmarks
how is this possible to reduce the number of landmarks in isaac ros vslam? are there parameters that can be adjusted to perform this?
my goal is to reduce the size of the map which is generated by vslam and make it more suitable for my application resources.
Hi @javadb1024
Thank you for your message.
The number of landmarks is automatically optimized from cvslam and is not an available parameter on Isaac Sim.
If you want just to debug the landmarks generated, there are two parameters:
https://nvidia-isaac-ros.github.io/repositories_and_packages/isaac_ros_visual_slam/isaac_ros_visual_slam/index.html#api
ROS Parameter Type Default Description
Debug/Visualization Parameters
enable_landmarks_view bool false If enabled, landmark pointcloud will be available for visualization.
path_max_size int 1024 The maximum size of the buffer for pose trail visualization.
Best,
Raffaello
