In page 05_USB3, there’s a ferrite-bead LB19, marked as 220ohm.
In the BOM file, I couldn’t find LB19, as well as no BLM18SG221TN1D which is the Part Number property, and there’s no LB with 220ohm.
Kindly ask for the p/n of this LB19.
Hi, which version schematic are you using? All 220ohm beads p/n are Z2K221-RM-15.
I’m sorry - used RevB. Now I see that it is not in RevC.
(http://developer.nvidia.com/embedded/dlc/jetson-tx1-tx2-developer-kit-carrier-board-c02-design-files
http://developer.nvidia.com/embedded/dlc/jetson-tx1-tx2-developer-kit-carrier-board-c02-bom)
