Ok, so I’m trying to apply Auvidea’s modifications to the device tree of TX2 module that came with the Dev kit.
AFAIK, there’re three different versions of binary device tree’s present on the device:
- /boot/tegra186-quill-p3310-1000-c03-00-base.dtb
- /dev/mmcblk0p15
- /sys/firmware/fdt
#1 is the smallest one of the three. Here’s the additions #2 has over #1:
root@tx2:/boot# diff -u tegra186-quill-p3310-1000-c03-00-base.dts original_from_flash.dts
--- tegra186-quill-p3310-1000-c03-00-base.dts 2018-01-06 18:22:09.710997578 -0500
+++ original_from_flash.dts 2018-01-06 21:34:18.807574114 -0500
@@ -13543,9 +13543,16 @@
chosen {
+ bootargs = "root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 ";
board-has-eeprom;
- bootargs = "console=ttyS0,115200";
stdout-path = "/serial@3100000";
+ plugin-manager {
+ odm-data {
+ l4t;
firmware {
And #3 is the largest, presumably having additinal device specific info passed from u-boot, like hardware MAC addresses, device S/N, etc. Here’s the diff:
root@tx2:/boot# diff -u tegra186-quill-p3310-1000-c03-00-base.dts original.dts
+++ original.dts 2018-01-06 18:22:52.010620883 -0500
@@ -1,7 +1,9 @@
/dts-v1/;
/memreserve/ 0x0000000080000000 0x0000000000010000;
+/memreserve/ 0x0000000092000000 0x0000000000042000;
+ serial-number = "0322117079514";
compatible = "nvidia,quill", "nvidia,tegra186";
interrupt-parent = <0x1>;
#address-cells = <0x2>;
@@ -5259,16 +5261,13 @@
ramoops_carveout {
+ reg = <0x0 0x96080000 0x0 0x200000>;
compatible = "nvidia,ramoops";
- size = <0x0 0x200000>;
alignment = <0x0 0x10000>;
- alloc-ranges = <0x0 0x0 0x1 0x0>;
no-map;
vpr-carveout {
- compatible = "nvidia,vpr-carveout";
- size = <0x0 0x2a000000>;
alignment = <0x0 0x400000>;
alloc-ranges = <0x0 0x80000000 0x0 0x70000000>;
reusable;
@@ -7523,6 +7522,8 @@
bpmp {
+ carveout-size = <0x200000>;
+ carveout-start = <0x77800000>;
compatible = "nvidia,tegra186-bpmp";
#stream-id-cells = <0x1>;
reg = <0x0 0xd000000 0x0 0x800000 0x0 0x3004e000 0x0 0x1000 0x0 0x3004f000 0x0 0x1000>;
@@ -13543,9 +13544,75 @@
chosen {
+ nvidia,ether-mac = "00:04:4b:8c:ce:f5";
+ nvidia,bluetooth-mac = "00:04:4b:8c:ce:f4";
+ nvidia,wifi-mac = "00:04:4b:8c:ce:f3";
+ linux,initrd-end = <0x9c000000>;
+ linux,initrd-start = <0x9c000000>;
+ bootargs = "root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 androidboot.serialno=0322117079514 bl_prof_dataptr=0x10000@0x277240000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 modprobe.blacklist=bcmdhd";
board-has-eeprom;
+ reset {
+ pmic-reset-reason {
+ reason = "NIL_OR_MORE_THAN_1_BIT";
+ register-value = "0x00";
+ pmc-reset-reason {
+ reset-level = [31 00];
+ reset-source = "MAINSWRST";
+ plugin-manager {
+ chip-id {
+ A02P = <0x1>;
+ configs {
+ 3310-display-config = <0x0>;
+ 3310-touch-config = <0x0>;
+ 3310-modem-config = <0x0>;
+ 3310-misc-config = <0x0>;
+ 3310-power-config = <0x0>;
+ 3310-mem-type = <0x0>;
+ ids {
+ 3310-1000-B01-D = <0x1>;
+ 3310-1000-B01 = "/i2c@c250000:module@0x50";
+ connection {
+ i2c@c250000 {
+ module@0x50 {
+ odm-data {
+ enable-sata-on-uphy-lane5 = <0x1>;
+ enable-pcie-on-uphy-lane4 = <0x1>;
+ enable-pcie-on-uphy-lane2 = <0x1>;
+ enable-pcie-on-uphy-lane1 = <0x1>;
+ enable-xusb-on-uphy-lane0 = <0x1>;
+ normal-flashed = <0x1>;
+ no-battery = <0x1>;
+ disable-sdmmc-hwcq = <0x1>;
+ disable-pmic-wdt = <0x1>;
+ enable-denver-wdt = <0x1>;
+ android-build = <0x1>;
+ enable-debug-console = <0x1>;
+ disable-tegra-wdt = <0x1>;
+ l4t;
firmware {
@@ -13558,6 +13625,6 @@
memory@80000000 {
device_type = "memory";
- reg = <0x0 0x80000000 0x0 0x70000000>;
+ reg = <0x0 0x80000000 0x0 0x70000000 0x0 0xf0110000 0x1 0x85e00000>;
Which one should I use as a reference to apply Auvidea’s modifications to? Would it be #1 or #2?
-albertr
