Hi niclas,
I had the same problem and after a lot of research I got to the conclusion that getting the reference or instance of the Behavior Script attached to a prim, if it’s possible, it is not the best way to communicate between a Behavior Script and a different one. Check this video for further explanations: Omniverse Developer Q&A - 1/6/2023
The way it is solved is by means of event streams. This way you can subscribe to a specific type of event, which you can create, and tell the Behavior Script that whenever this type of event is pushed, call a specific function. Check this doc to learn more about events: Event streams
Let’s follow a simple guide right now. First, go to the Behavior Script and write, for example, on the on_init() method the following code:
import omni.kit.app
import carb.events
TEST_EVENT = carb.events.type_from_string("omni.my.extension.TEST")
bus = omni.kit.app.get_app().get_message_bus_event_stream()
self.sub1 = bus.create_subscription_to_push_by_type(TEST_EVENT, self.test)
Then add the specified function:
def test(self, e):
print("It works!")
Finally, go to the other python script and, again, follow this steps. First, get the exact same event and the bust event stream:
import omni.kit.app
import carb.events
To finish, push the event through the bus (you can add some information using the payload argument):
bus.push(TEST_EVENT, payload={"info": "this is a text"})
In order this to work properly, you need to subscribe first and then push the event.
I hope this solves your problem :)
