Hi @pekka.varis ,
According to NVIDIA developer, the current version of Machinima doesn’t support smooth refinement (aka subdivision) on skeleton mesh (e.g. mesh of character with a skeleton).
Support will come in future version.
thanks,
Weien
For now, if you absolutely need this feature, you can use the Maya omniverse point cache export feature to push out a second copy of the iclone usd scene, and this mesh will support refinements inside of create. As far as I know I think you will need to relink the mdl shaders from the original iclone usd exported project though.
Any chance we could get omniverse point cache exporting directly from iclone? I think this would do the trick.
Now that I think about it, it may also work to export an alembic sequence from iclone and do the same thing, relinking the converted ov mdl shaders to the alembic mesh, although I haven’t tested this just yet.
I forgot to mention: if you do go through the steps of bringing your iclone usd into maya and export it out via animated point cache, be sure to set the subdivision scheme (under the refinement section of your objects) to catmullClark as it will not be enabled by default. This is an important step for getting the smoothing to kick in.
Was Maya the child of Sumatra? The newborn Soft Image?
I used to learn & test Soft Image as a daytime job at -90, it was a super expensive license that was allowed only for non-commercial production!
