I have followed the guide for image-based OTA here: Software Packages and the Update Mechanism — Jetson Linux Developer Guide documentation
I was able to successfully update the rootfs and bootloader from jetson 35.3.1 to jetson 35.4.1 on an Orin dev kit.
However, when trying to reflash with jetson 35.4.1, I am getting the following error:
# L4T BSP Information:
# R35 , REVISION: 4.1
# User release: 0.0
# Target Board Information:
# Name: jetson-agx-orin-devkit, Board Family: t186ref, SoC: Tegra 234,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying emc_fuse_dev_params(/home/ubuntu/Documents/latest/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/ubuntu/Documents/latest/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3701-0000.dts)... done.
copying misc_config(/home/ubuntu/Documents/latest/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3701-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/home/ubuntu/Documents/latest/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0215 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0226 ] File rcm_state open failed
[ 0.0226 ] ERROR: failed to read rcm_state
[ 0.0226 ]
[ 0.0245 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0247 ] Assuming zero filled SBK key
[ 0.0231 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[ 0.0300 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[ 0.0418 ] Parsing partition layout
[ 0.0433 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0449 ] Kernel DTB used: None
[ 0.0449 ] WARNING: dce base dtb is not provided
[ 0.0449 ] Parsing partition layout
[ 0.0458 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0472 ] Creating list of images to be signed
[ 0.0482 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0492 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0515 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0523 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0583 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0591 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0636 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0651 ] adding BCH for mb2_t234_aligned.bin
[ 0.0675 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0789 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0808 ] adding BCH for mb2_t234_aligned.bin
[ 0.0956 ] Filling MB1 storage info
[ 0.0957 ] Parsing dev params for multi chains
[ 0.1040 ] Generating br-bct
[ 0.1051 ] Updating dev and MSS params in BR BCT
[ 0.1052 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.1085 ] Updating bl info
[ 0.1100 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.1112 ] WARNING: boot chain is not completed. set to 0
[ 0.1126 ] Generating signatures
[ 0.1145 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1147 ] Assuming zero filled SBK key
[ 0.1325 ] Warning: pub_key.key is not found
[ 0.1311 ] Parsing dev params for multi chains
[ 0.1312 ] Generating br-bct
[ 0.1324 ] Updating dev and MSS params in BR BCT
[ 0.1325 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.1355 ] Updating bl info
[ 0.1390 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1406 ] WARNING: boot chain is not completed. set to 0
[ 0.1433 ] Get Signed section of bct
[ 0.1467 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.1492 ] Signing BCT
[ 0.1511 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1513 ] Assuming zero filled SBK key
[ 0.1546 ] Sha saved in br_bct_BR.sha
[ 0.1549 ] Warning: pub_key.key is not found
[ 0.1532 ] Updating BCT with signature
[ 0.1540 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.1548 ] Offset :4608 Len :3584
[ 0.1557 ] Generating SHA2 Hash
[ 0.1576 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.1578 ] Assuming zero filled SBK key
[ 0.1579 ] Assuming zero filled SBK key
[ 0.1621 ] Sha saved in br_bct_BR.sha
[ 0.1610 ] Updating BCT with SHA2 Hash
[ 0.1622 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.1631 ] Offset :4608 Len :3584
[ 0.1638 ] Offset :68 Len :8124
[ 0.1638 ]
[ 0.1639 ] Generating coldboot mb1-bct
[ 0.1649 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1658 ] MB1-BCT version: 0.10
[ 0.1660 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1662 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1664 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1666 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.1669 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.1672 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.1678 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.1679 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.1679 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.1679 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.1679 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.1679 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.1679 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.1679 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.1679 ]
[ 0.1679 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1679 ] Added Platform Config 9 data with size :- 100
[ 0.1679 ]
[ 0.1682 ] Updating mb1-bct with firmware information
[ 0.1717 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1755 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1775 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.1783 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1808 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1810 ] Assuming zero filled SBK key
[ 0.1833 ] Warning: pub_key.key is not found
[ 0.1834 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1852 ] Generating recovery mb1-bct
[ 0.1862 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1871 ] MB1-BCT version: 0.10
[ 0.1872 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1878 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1883 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
[ 0.1886 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.1886 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.1886 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.1886 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.1886 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.1886 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.1886 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.1886 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.1886 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.1886 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.1886 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.1886 ]
[ 0.1886 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1886 ] Added Platform Config 9 data with size :- 100
[ 0.1886 ]
[ 0.1887 ] Updating mb1-bct with firmware information
[ 0.1898 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1925 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.1943 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.1952 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.1978 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1979 ] Assuming zero filled SBK key
[ 0.1998 ] Warning: pub_key.key is not found
[ 0.1992 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.2037 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.2037 ] Copying signatures
[ 0.2085 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.2191 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.2193 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.2193 ] Boot Rom communication
[ 0.2209 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.2219 ] BR_CID: 0x80012344705DD8108400000009FE0140
[ 0.3298 ] Sending bct_br
[ 0.4318 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Reading board information failed.
To troubleshoot, here have been my steps:
- Replaced the USB-C cable between the orin and host - no change
- Reflashed another Orin dev kit using the same image without the OTA changes and was successful
- Attempted to flash other jetson versions and images - no change
I believe I have narrowed the issue down to the OTA changes I made. I have never come across this error before when flashing.
My question is, why would this behaviour occur and how do I fix it?
