Reflashing Jetson TX1 without recovery USB
I am part of a FIRST robotics compeition team that has a TX1. It currently doesn’t finish booting, and I believe that it needs to be flashed, however the recovery USB port is broken.
Is there a way to load the OS image directly onto the SD card or SATA storage and boot off that?
You could try to boot from SD card. Though I guess it would be better if you could get your micro usb fixed…
Ref: https://www.jetsonhacks.com/2017/01/26/run-jetson-tx1-sd-card/
