Is there a way to get reflections from the sky (a sky dome for instance) on the model, without seeing the sky?
I doubt, but with alpha channel rendering for sure.
Composite the sky away by using render 1. but with alpha channel of render 2.
Hey, I just watched the twitch stream where dawid.cencora used this the correct way. I made a short video about this to you, since he is covering so much more at the sculpting stream.
