I already posed this question to the German support team but they told me I have to register as a dev and file it here:
Anyway, I use my PC on CachyOS (KDE Plasma) with RTX 4080S and the latest 615 driver sometimes to connect it to my TV (Sony KD-65XH9005) which is a 4K TV. Here I have the problem that the maximum refresh rate won’t allow more than 30 Hz which is a chore on the eyes. It won’t matter if I connect the machine to my Yamaha AV receiver via ARC or directly to the TV’s HDMI ports - the issues persists. Now you could think that the cable is the problem or the TV is simply not compatible to the card (which would be extremely weird). But none of this seems to be the cause:
- Loading up Windows 11 via dual boot does not give me any headache at all. Here 60 Hz work flawless. The hardware is the same except that I switch the OS.
- I use the exact same cable for a GMKTec G3 Plus mini PC with N150 on the exact same TV as a media center, with CachyOS as well, and I get the full 60 Hz
I remember last year, when CachyOS still offered the option to chose the display server (Xorg or Wayland) at the LogIn prompt, I just for fun picked Xorg once and the TV suddenly got 60 Hz. This also reminds me of the fact that this is a problem I experience since a long time and over many driver versions. 580 had the problem as well as 595. So I am pretty sure right now the problem is on the driver side.
