We have a linux system Rocky 8.7. (with Driver version 550.90.07) That does not respect all of the refresh rate in the Nvidia server GUI that the monitor manufaturer says the monitor can support. So this looks to be some sort of EDID error maybe ? In xrandr the refresh rates are also not showing and if we try to manually force to create a line in xrandr there is an error. Is there some way to turn off EDID and force the Nvidia server GUI to show the fresh rates and also xradr to behave ? We went back into our records and in the past older Nvidia drivers did support the the same monitor refresh rates and so something seems to of changed over the years. We have checked with different models of monitor and seeing the error with those as well. thank you
Related topics
Topic | Replies | Views | Activity | |
Must change refresh rate after every reboot | 8 | 7831 | July 14, 2017 | |
Monitor (refresh frequency) overclocking in Linux is not available | 3 | 3463 | June 2, 2019 | |
How to Set Update Rate of NVIDIA 1080ti in Ubuntu16.04 | 7 | 746 | October 22, 2019 | |
Latest Nvidia driver [530.41.03] does not allow maximum refresh rate of connected monitor | fedora 37 | GTX 1080 | 13 | 2459 | February 2, 2024 | |
Highest refresh rate missing on lower resolutions | 4 | 2221 | August 19, 2021 | |
Wayland Monitor Refresh Rate | 2 | 2336 | May 12, 2017 | |
Overriding EDID makes VRR stop working under WAYLAND -> ( "vrr_capable" (immutable): range [0, 1] = 0 ) | 28 | 1145 | March 10, 2025 | |
Wrong EDID data returned? | 16 | 1042 | April 14, 2024 | |
Cant change refresh rate on nvidia optimus 730m and Ubuntu | 3 | 1417 | October 14, 2021 | |
I can't adjust the refresh rate in Nvidia Settings on Ubuntu 20.04 and Pop OS 20.10 | 21 | 12590 | October 12, 2021 |
