hi,
can anyone share the size of the screw ( part number ) used for the TX2 SOM (X4) in eval-board?
thanks
Following link may help you:
http://eshopshemeks.com/shop/shopdetail.html?branduid=758198&search=&sort=
head in diameter: 6mm
head depth in diameter: 1.7mm
screw in diameter: 2.5mm (but, it should be checked by Calipers more carefully)
bolt length: 10mm
Someone else could check detailed spec.
Thanks,
