Regarding 25GbE configuration issues during Jetson Thor QSFP startup
I am trying to enable 25GbE on a Jetson Thor device.
The system version I am using is JetPack 7.2.1.
I am following the official NVIDIA documentation:
After flashing the system with 25GbE enabled onto the Jetson Thor, the ports fail to establish a link.
I then reverted the system to the 10GbE configuration, and the ports connected normally.
What could be causing this issue?
Is this NV devkit or a custom board?
Hi, WayneWWW
I am using the Jetson AGX Thor Developer Kit.
The cause of the issue has been identified: the HSB FPGA failed to boot up correctly.
