Regarding 945-13766-0005-000
Hello, What are the input power ratings of the DC power supply adapter included with 945-13766-0005-000 | NVIDIA® Jetson Orin™ Nano Super Developer Kit?
The NVIDIA Jetson Orin Nano Developer Kit (P3766) is a comprehensive development platform that includes the following components:
  1. Jetson Orin Nano 8GB module with SD card slot (P3767-0005): This is a commercial-grade module that is specifically designed for the developer kit. It has 8GB of memory and an SD card slot, which is not available on the commercial-grade Jetson Orin Nano modules (P3767-0003 and P3767-0004).
  2. Carrier board: The carrier board is a reference design that provides a platform for the Jetson Orin Nano module to connect to various peripherals and interfaces. It supports all the Jetson Orin Nano Series and Jetson Orin NX Series modules.
  3. Power supply: The developer kit includes a power supply that provides the necessary power to the Jetson Orin Nano module and the carrier board.
  4. Software: The developer kit includes a software image that can be loaded onto the Jetson Orin Nano device. This image includes the NVIDIA JetPack SDK, which provides a comprehensive set of tools and libraries for developing applications on the Jetson platform.
  5. Supporting documentation: The developer kit includes supporting documentation, such as user manuals, datasheets, and technical notes, that provide detailed information on the Jetson Orin Nano module, the carrier board, and the software.
  6. Code samples: The developer kit includes code samples that demonstrate how to use the various features and interfaces of the Jetson Orin Nano module.
Comparison with other Jetson Orin Nano modules:
  • The Jetson Orin Nano 8GB module with SD card slot (P3767-0005) included in the developer kit is similar to the commercial-grade Jetson Orin Nano 8GB module (P3767-0003), but it has an SD card slot, which is not available on the commercial-grade module.
  • The Jetson Orin Nano 4GB module (P3767-0004) is another commercial-grade module that has less memory than the module included in the developer kit.
In summary, the NVIDIA Jetson Orin Nano Developer Kit (P3766) is a comprehensive development platform that includes a Jetson Orin Nano 8GB module with SD card slot, a carrier board, power supply, software, supporting documentation, and code samples. It is designed to provide developers with a complete platform for developing applications on the Jetson Orin Nano module.
The power supply in the Dev Kit is 100-240V AC, 50/60Hz input.
