I use the jetson-io tool to activate the spi and use the spi well.
If you make /proc/device-tree with dts as shown below,
nvidia,function = “rsvd2”; It’s like this.
Shouldn’t it be spi1 instead of rsvd2?
But, what is the reason that there is no problem with spi communication even when nvidia,function = “rsvd2” like this?
The contents of spi activation using jetson-io.py are
Is it not reflected in /proc/device-tree?
After activating spi using jetson-io.py, you can check the waveform change through the oscilloscope.
So, as expected, if you extract dts through the following command,
I was expecting nvidia,function = '“spi1”, but
I want to know the reason.
