Regarding AE exposure time settings
Hello. I have a question about the “min_exp_time” and “max_exp_time” in the device tree.
I am using Jetson Xavier NX r32.6.1.
I have created a device tree for an image sensor with multiple operating modes and performed verification testing.
As an example of the mode settings, let’s say it is described as follows:
mode0 {
    min_exp_time = "14";
    max_exp_time = "8333";
mode1 {
    min_exp_time = "18";
    max_exp_time = "16666";
mode2 {
    min_exp_time = "22";
    max_exp_time = "33333";
In this case, I execute the following command:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 sensor-mode=1 ! "video/x-raw(memory:NVMM), framerate=30/1" ! nvvidconv ! videoconvert ! ximagesink
I expected the AE control range to be 18 to 16666 [us], but the actual behavior was 22 to 8333 [us]. This behavior was the same even when starting with mode0 or mode2.
For example,
gst-launch-1.0 nvarguscamerasrc sensor-id=0 sensor-mode=1 exposuretimerange="18000 16666000" ! "video/x-raw(memory:NVMM), framerate=30/1" ! nvvidconv ! videoconvert ! ximagesink
did not change the behavior.
However,
gst-launch-1.0 nvarguscamerasrc sensor-id=0 sensor-mode=1 exposuretimerange="16666000 16666000" ! "video/x-raw(memory:NVMM), framerate=30/1" ! nvvidconv ! videoconvert ! ximagesink
resulted in the control being applied within the range of 18 to 16666 [us].
Is this behavior due to the AE specifications, or is it a problem with my device tree configuration?
hello Naoki.Nishimura,
it’s known issue that Argus is using the smallest of the max_exp_time property out of all the modes. that’s due to we’ve initialize AE limits after iterating through all sensor modes.
so,
it’s currently not supported for allowing per-mode exposure time settings.
Thank you for your quick response.
I understand the current specifications.
