This is my first post. I just set up my Xavier using an SD card as boot drive (still looking to use eMMC if its any better).
Question: Can the Xavier run off USB-C power given it supports PD? Or is PD in this meant as a way to provide power to other devices?
Thanks in advance!
Not able to understand the request. Please give more detail. For USB Type-C ports, there are J512 and J513 on developer kit. You may speficy which port you would like to use.
The specs describe the USB-C connectors as supporting USB-C PD. Usually, this means the device is able to accept power through the USB-C connector or provide it, i.e.: Fast charge another USB-C device.
I’m chasing whether the AGX Xavier can function off USB-C power.
