Regarding enabling nfs on 6.0.8.1
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
Hi Nvidia,
I see in the 6.0.8.1 release notes
Disables debugging, logging and profiling, console, SSH/NFS for Security in page 7/25 . Is there a way we can enable nfs on 6.0.8.1 for test purposes ?
Regards,
Sistla.
The release available on the developer site is the standard one instead of the safety one so it should be the same as the previous release.
hey vick,
Thank you , i am trying to do mount a remote directory on orin , this was working for sure on on 6.0.6
@tegra-ubuntu:~$ sudo mount -t nfs -o 10.xxx.xxx.xxx:/home/xxxxx/docker_share/606-ws/build-linux-64/ /nfs/docker_share/
mount.nfs: access denied by server while mounting 10.xxx.xxx.xxx:/home/xxxxx/docker_share/606-ws/build-linux-64/
@tegra-ubuntu:~$
Does this command still successfully mounting the NFS share on version 6.0.6? Could there be an issue on the server side or with the connection?
NFS share mounting is confirmed to be functional on version 6.0.8.1. Please ensure to check your server-side configuration.
sorry @SivaRamaKrishnaNV Yes i was able to get it working, so network proxy issues blocked . I updated my box to 608 and at same time moved my box to different network. ANyways sorry for confusion and thankyou for help
