The memcpy speed couldn’t keep up with the dqBuffer speed
Is this because NvBuffer is dma_buf?
Is it the impact of multithreading?
Is it the effect of dma_buf?
Thank you.
If you call memcpy(), it consumes CPU loading. A better way is to leverage hardware converter. You can create NVvBuffer and call NvBufferTransform() for copying data from one NvBuffer to the other.
You tell me the usage of using NvBufferTransform() functions is in 12_camera_v4l2_cuda sample app.
Related to Using the function similar to what you were trying to use memcpy,
Can I see this in different example?
of you can give me some code sniffet?
Thank you.
You may also refer to 00_video_decode or 07_video_convert.
