Regarding the issue of deepstream test3 perf mode
**• Hardware Platform (Jetson / GPU) Jetson
**• DeepStream Version 6.2
**• JetPack Version (valid for Jetson only) 5.0.2
**• TensorRT Version 8.4.1.5
**• CUDA 11.4.239
**• cuDNN 8.4.1.50
**• Issue Type( questions, new requirements, bugs) questions
**•Requirement details:I have a pipeline deepstream test3
questions:It can run normally when I set export NVDS-TEST3-PERF_MODE=0; The following issues occur when exporting NVDS-TEST3-PERF_MODE=1.
eg.
/data/deepstream-6.2/sources/apps/sample_apps/deepstream-test3$export NVDS_TSET3_PERF_MODE=1
/data/deepstream-6.2/sources/apps/sample_apps/deepstream-test3$ ./deepstream-test3-app ./dstest3_config.yml
Now playing : file:///home/nvidia/work/data/gpu_decode/output.mp4
PERF_MODE
(deepstream-test3-app:2395053): GLib-GObject-CRITICAL **: 13:58:20.961: g_object_set: assertion ‘G_IS_OBJECT (object)’ failed
One element in source bin could not be created.
Failed to create source bin. Exiting.
There may be a problem with your installation environment, so that the nvurisrcbin plugins cannot be created. Could you update the DeepStream to the latest version 7.1?
Thank you for your reply. Can you explain why ‘Opening in BLOCKING MODE’ still appears in the log when I set NVDS-TEST3-PERF_MODE to 1.
----------------------------------------------PERF_MODE: 1
Decodebin child added: src_cap_filter_nvvidconv
Decodebin child added: nvv4l2decoder2
Decodebin child added: h264parse10
Decodebin child added: capsfilter10
Decodebin child added: depay
Decodebin child added: parser
Decodebin child added: tee_rtsp_pre_decode
Decodebin child added: dec_que
Decodebin child added: tee_rtsp_post_decode
Decodebin child added: decodebin
Decodebin child added: queue
Decodebin child added: nvvidconv
Decodebin child added: nvv4l2decoder9
Decodebin child added: nvv4l2decoder10
NvMMLiteOpen : Block : BlockType = 261
These logs has nothing to do with the PERF_MODE. This is related to the decoder. You can refer to this topic 257153.
