Regarding the jetson nano module replacement
but it is still giving error of not detecting the jetson nano device
Did you jumper the recovery pins during power up or power reset? It does have to be in recovery mode prior to detect.
Yes sir
I connected jumper on FC rec and GND
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
Yes sir
The device which I purchased is yahboom company
So they have resolved the issue
Just one error message is coming
“System throttled due to over current”
during working
Please guide me to resolve this issue
Do you have DC power supply to observe the input voltage and current with oscilloscope? That will be helpful to check if any voltage drop during power on. If over current alarm come out, you may need to check the input power and the devices attached to Jetson, as that might need some more power consumption.
Ok
