Regarding the problem of no power on the jetson nano devkit carrier board
Have any of you experienced any problems with booting when you unplug the dc jack from the jetson nano devkit carrier board and immediately plug the dc jack back in?
If so, does anyone know a solution?
Thank you.
Why do you have to remove the dc jack and put it back immediately ? And what kind of solution do you expect here?
Cannot even understand what is the exact problem. Fail to boot again?
If the power is turned on again after a power outage, the nano may not turn on.
And above all, if the power does not come on when you repeatedly unplug and plug in this way, customers judge that there is a problem with the product.
Thank you.
Ok. Can you describe what is your “may not turn on” ? The power LED is even not ON? Or just no response from monitor/keyboard?
The power LED is even not ON.
Thank you.
Then it sounds like hardware broken. How many devices have such situation?
Sorry.
It was a problem that occurred on a custom board I made,
The problem was caused by residual charge remaining.
I solved it now.
Thank you.
Hi Hodu,
Can you please explain how you resolved the problem?
