Regarding the use of YOLOV8S model combined with JPS Docker
**• Hardware Platform (Jetson / GPU)6.1
**• DeepStream Version 7.1
**• JetPack Version (valid for Jetson only)6.1
**• TensorRT Version 10.3
**• NVIDIA GPU Driver Version (valid for GPU only)540.4.0
The Type of this mechine is Orin AGX 64G
I would like to inquire about two questions regarding the use of YOLOV8S model combined with JPS Docker
  1. There are differences in the size of yolov8s_DAT_noqdq.onnx compared to the normal PT I downloaded from the official website
  2. The naming of yolov8s_DAT_noqd_DLA.engine cannot be converted by the program, and the program usually outputs a suffix of b8,dla0uint8
Yes, we optimized YOLOv8s model. Please use the YOLOv8s model from JPS container.
You can rename the engine file.
deepstream-yolov8s-detect-dla0-v103.log (36.6 KB)
Setting min object dimensions as 16x16 instead of 1x1 to support VIC compute mode.
0:00:00.739920824 ^[[32m 19^[[00m 0xaaab12107d90 ^[[36mINFO ^[[00m ^[[00m nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary_gie>^[[00m NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/configs/…/models/yolov8s_Detector/yolov8s_DAT_noqdq_DLA.engine
0:00:00.739983959 ^[[32m 19^[[00m 0xaaab12107d90 ^[[33;01mWARN ^[[00m ^[[00m nvinfer gstnvinfer.cpp:681:gst_nvinfer_logger:<primary_gie>^[[00m NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:2026> [UID = 1]: Backend has maxBatchSize 1 whereas 8 has been requested
0:00:00.739997047 ^[[32m 19^[[00m 0xaaab12107d90 ^[[33;01mWARN ^[[00m ^[[00m nvinfer gstnvinfer.cpp:681:gst_nvinfer_logger:<primary_gie>^[[00m NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2201> [UID = 1]: deserialized backend context :/configs/…/models/yolov8s_Detector/yolov8s_DAT_noqdq_DLA.engine failed to match config params, trying rebuild
0:00:00.749479482 ^[[32m 19^[[00m 0xaaab12107d90 ^[[36mINFO ^[[00m ^[[00m nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary_gie>^[[00m NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2106> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
Please change the batch size of YOLOV8s based on the guide: DeepStream Perception — Jetson Platform Services documentation
Can YOLOV8 use INT8?
How used?
YOLOv8s on DLA already use INT8. It already the best performance.
May I ask how to modify the configuration file?
Which one should be used for the Calib file?
The default configuration file config.inpfer_primary_yoloV8.txt uses fp16
Calibration file is in the JPS docker container. You can generate with calibration file based on below command line:
$ docker run -it --rm --net=host --runtime nvidia  -w /root -v /tmp/.X11-unix/:/tmp/.X11-unix  -e DISPLAY=$DISPLAY -v /mnt/share/jps2/ai_nvr/config/deepstream/:/ds-config-files/ nvcr.io/nvidia/jps/deepstream:7.1-public-v1
$ cd yolov8s-files/
$ cp yolov8s_DAT_noqdq_DLA.engine yolov8s_DAT_noqdq_DLA.engine-bak
$ trtexec --onnx=yolov8s_DAT_noqdq.onnx --fp16 --int8 --verbose --calib=yolov8s_DAT_precision_config_calib.cache --precisionConstraints=obey --layerPrecisions=Split_36:fp16,Reshape_37:fp16,Transpose_38:fp16,Softmax_39:fp16,Conv_41:fp16,Sub_64:fp16,Concat_65:fp16,Mul_67:fp16,Sigmoid_68:fp16,Concat_69:fp16 --saveEngine=yolov8s_DAT_noqdq_DLA.engine --useDLACore=0 --allowGPUFallback
May I ask how to generate yolov8s_DAT_precision_comfig.calib.cache?
I think this topic can be fixed, but DeepStream-Yolo/docs/INT8Calibration.md at master · marcoslucianops/DeepStream-Yolo · GitHub
I can’t open it temporarily
Please use the model and the calibration file in the JPS DeepStream container:
$ cd yolov8s-files/
I was trying to configure ai_nvr using DeepStream 7.1 and YOLOv8 with multiple streams. I followed the guide you suggested, but I wasn’t able to complete it because it failed when trying to build deepstream_test5 due to missing dependencies. I tried fixing it by installing the dependencies, but I couldn’t find a solution related to cuda_runtime_api.h.
Additionally, I noticed that l4t-repo.nvidia.com:80 doesn’t work every time I try to install something with apt.
I then repeated the process using the “deepstream:7.1-triton-multiarch” image, and it built successfully.
So, my question is: Do we need to copy the yolov8s-files folder into the Triton container from the public container, or is there a better way? Maybe I’m missing something.
Setup:
  • Hardware Platform: Jetson Orin NX 16GB
  • Jetpack 6.1 (L4T 36.4)
  • TensorRT Version 10.3.0.30
Please submit new topic for your question. Thanks!
