How do I modify the Makefile to create the filename.a static library by modifying the makefile in the /usr/src/jetson_multimedia_api/samples/common/algorithm/cuda directory?
I am not familiar with cuda, so I ask a question.
Thank you.
Thank you.
Please check if this webpage helps:
Or may need other users to share experience.
