Regarding ubuntu18.04 on jetson nano
Hello
Even if I click the date&time icon, the UI for setting the time zone does not appear.
Can you give me any advice?
Thank you.
As I said in other posts, please describe your problem more clearly.
What is the exact problem you have? Which software release are you using?
Hi neuezeal,
After run “unity-control-center” pipeline on Nano, we can see “System Settings” pop-up.
We tried on r32.4.4 too.
The control panel was not displayed by clicking the settings icon.
Solved it.
Thank you.
please share how do you solve it.
The UI didn’t appear even when I clicked the date and time icon.
When I checked, it seems that there was a problem because the control panel UI did not appear.
When the date and time and the control panel (unity-control-center) seem to be related and the control panel UI is changed to display properly, the date and time UI also works properly.
Thank you.
According to the message you are missing a library for EGL rendering. libwebkit2gtk-4.0.so.37 needs another library with symbol gst_gl_display_egl_new_with_egl_display. If you have that library with the gst egl symbol, then it is no longer found. That or the upgrade replaced the library with that symbol.
I couldn’t tell you which library provides symbol gst_gl_display_egl_new_with_egl_display, but somewhere there might be a list of what libwebkit2gtk-4 depends on.
