Regex error
Does anyone know how to solve this issue?
I tried these steps, but itstill did not work.
2.3.2. Solution
  1. Make sure that mlx-regex is running. On the DPU, run:
dpu# systemctl status mlx-regex
  1. You will probably see the Active line as Failed or inactive. To fix this, on the DPU, run:
dpu# systemctl restart mlx-regex
  1. Make sure that the RegEx device is active. Run:
You should see the Active line as active (running).
4. If the Active line is still Failed, you probably need to restart the InfiniBand (RDMA) driver. On the DPU, run:
dpu# /etc/init.d/openibd restart
  1. Restart the RegEx device again. Run:
  1. This should fix the issue. Verify that the RegEx device is active again. Run:
