Region Labeling in Cuda Optimising for Cuda, memory etc
I’m investigating the use of CUDA to improve the real-time performance of a bit of the image processing software for a project I’m working on. I’ve been looking at using NPP and CUFFT but I need to have a region labelling algorithm as part of the processing pipeline.
So I’ve just finished writing the region labeling algorithm (my first CUDA program). I used the 4th Kernel described in section 4 in http://www.massey.ac.nz/~kahawick/cstn/089/cstn-089.pdf except I’m only labeling regions in an image that are non-zero.
I’ve posted the code below. The paper gives a fuller description of the algorithm but since I’m new to CUDA I was wondering if anyone would be able to give me some advice regarding possible optimizations. I am currently using global memory throughout and using a single thread per element so these were two areas that I could possibly improve, by either using shared memory or loading a number of pixels per thread (since some pixels will be zero and the threads with these pixels don’t really do anything).
The problem with using shared memory is that I’m unsure how to access the elements in different blocks, and I’m not really sure what the optimum number of elements to process in each thread would be.
If anyone has any advice that would be brilliant.
#ifndef LABELREGIONSKERNEL_CU
#define LABELREGIONSKERNEL_CU
#include <cutil_inline.h>
#include <math.h>
#include "LabelRegions.h"
#define min_valid(a, b) (a < b ? a == 0 ? b : a : b == 0 ? a : b)
__device__ int md;
__global__
void kernel_bc_initialise(int *pMarkers, int *pLut, int w, int h)
	// Get the id for the element
	unsigned int x = blockIdx.x * blockDim.x + threadIdx.x;
	unsigned int y = blockIdx.y * blockDim.y + threadIdx.y;
	unsigned int id = x + y * w;
	// if not in range then return
	if (x > w-1 || y > h-1)
		return;
	// initislise the image and lookup table
	pLut[id] = pMarkers[id] = pMarkers[id] == 0 ? 0 : id+1;
__global__
void kernel_bc_scan_image(int *pSrc, int *pLut, int w, int h)
	int pn, ps, pe, pw, pc, min;
		return;
	// read the current element id
	pc = pSrc[id];
	// if the label is zero then return
	if (pc == 0)
		return;
	// get the north, south, east and west pixel values
	pn = (y > 0	 ? pSrc[x + (y - 1) * w] : 0);
	ps = (y < h - 1 ? pSrc[x + (y + 1) * w] : 0);
	pw = (x > 0	 ? pSrc[(x - 1) + y * w] : 0);
	pe = (x < w - 1 ? pSrc[(x + 1) + y * w] : 0);
	// find the minimum value of the four points
	min = min_valid(pn, pw);
	min = min_valid(min, pe);
	min = min_valid(min, ps);
	// if the minimum label is less than the current then set it
	// in the lookup table
	if (min < pc && min != 0) {
		pLut[pc-1] = min < pLut[pc-1] ? min : pLut[pc-1];
		md = 1;
__global__
void kernel_bc_analyse_lut(int *pSrc, int *pLut, int w, int h)
	int label, ref;
		return;
	// get the label for the current element
	label = pSrc[id];
	// if the label is equal to the id
	// then this thread takes ownership of
	// the label
	if (label == id+1) {
		// loop through the lookup table to
		// find the root label and set that as
		// the label for the current element.
		ref = label-1;
		label = pLut[id];
		while (ref != label-1) {
			ref = label-1;
			label = pLut[ref];
		pLut[id] = label;
__global__
void kernel_bc_colour_blobs(int *pSrc, int *pLut, int w, int h)
	int ref;
		return;
	// Set the value of the element using the lookup table
	ref = pLut[pSrc[id]-1];
	pSrc[id] = pSrc[id] == 0 ? 0 : pLut[ref-1];
__global__
void kernel_bc_pack_colours(int *pSrc, int *pLut, int w, int h)
	int label;
		return;
	// set the lut value at this point to zero
	pLut[id] = 0;
	label = pSrc[id];
		pLut[label] = label;
void gpu_label_regions(int *pMarkers, int w, int h, int *pBuffer)
	int *pMd;
	int md = 0;
	// Allocate and copy variable
		cutilSafeCall(cudaMalloc((void**) &pMd, sizeof(int)));
	// copy symbol value
	cudaMemcpyToSymbol("md", &md, sizeof(int), 0, cudaMemcpyHostToDevice);
	// setup execution parameters
		dim3  threads( 8, 8, 1);
	dim3  grid( ceil(float(w)/threads.x), ceil(float(w)/threads.y), 1);
		// initialise the markers and buffer
		kernel_bc_initialise<<< grid, threads >>>(pMarkers, pBuffer, w, h);
	// scan the image for the first time to see if we need to do anything
	kernel_bc_scan_image<<< grid, threads >>>(pMarkers, pBuffer, w, h);
	// get the value of md back from the device
	cutilSafeCall(cudaMemcpyFromSymbol(&md, "md", sizeof(int), 0,
			cudaMemcpyDeviceToHost));
	// continue to loop through until no more changes need to be made
	while (md != 0) {
		cudaMemcpyToSymbol("md", &(md = 0), sizeof(int), 0,
		// analyse the changes in the lookup table
		kernel_bc_analyse_lut<<< grid, threads >>>(pMarkers, pBuffer, w, h);
		// update the colour of the blobs
		kernel_bc_colour_blobs<<< grid, threads >>>(pMarkers, pBuffer, w, h);
		// scan the image to see if we need to do anything
	// free the device memory
		cutilSafeCall(cudaFree(pMd));
int main()
	int *pSrc;
	int *pLut;
	const int w = 9;
	const int h = 9;
	// allocate the memory for the host data
	int pMarkers[w*h] = {
		1, 1, 1, 1, 1, 1, 0, 0, 0,
		0, 0, 0, 1, 1, 1, 1, 0, 0,
		1, 1, 0, 1, 1, 1, 1, 0, 0,
		1, 1, 1, 0, 1, 1, 1, 1, 0,
		1, 0, 0, 0, 0, 1, 1, 1, 1,
		1, 0, 1, 1, 0, 0, 1, 1, 1,
		1, 0, 0, 1, 1, 0, 0, 1, 0,
		1, 1, 0, 0, 0, 0, 1, 1, 0,
		0, 1, 1, 1, 1, 1, 1, 1, 1
	int pLookup[w*h];
	// Allocate cuda device memory
		cutilSafeCall(cudaMalloc((void**) &pSrc, w*h*sizeof(int)));
		cutilSafeCall(cudaMalloc((void**) &pLut, w*h*sizeof(int)));
	// copy marker array across to the device
	cutilSafeCall(cudaMemcpy(pSrc, pMarkers, w*h*sizeof(int), cudaMemcpyHostToDevice));
	// label the regions
	gpu_label_regions(pSrc, w, h, pLut);
		// check if kernel execution generated and error
		cutilCheckMsg("Kernel execution failed");
	// Copy the marker data back to the host
		cutilSafeCall(cudaMemcpy(pMarkers, pSrc, w*h*sizeof(int), cudaMemcpyDeviceToHost));
		cutilSafeCall(cudaMemcpy(pLookup, pLut, w*h*sizeof(int), cudaMemcpyDeviceToHost));
		cutilSafeCall(cudaFree(pSrc));
	cutilSafeCall(cudaFree(pLut));
	// print
	for (int j = 0; j < h; ++j) {
		for (int i = 0; i < w; ++i) {
			cout << pMarkers[i+j*w] << " ";
		cout << endl;
	system("pause");
	return 0;
#endif
Fast connected component labelling for images was the topic of a CUDA programming contest a few months back.
Some entrants (including the winner) posted their code. There’s an interview here.
I recently spent a month developing blob extraction, which uses component labeling as a subroutine (find all connected regions and compute quantities like area, perimeter, center mass) and I’m able to get 12 Gpixels/s for sparse blobs on Tesla 1060.
I’ve asked Micha Riser (winner) what his performance was (the contest used some non-physical quantity for scoring) and it ranged from 166 to 330 Mpixels/s. The comparison isn’t too fair because the performance is very dependent on the blob density - the worst case rectangular band image can multiple the run time 100x. The images I’m using are for defect analysis and the blobs are quite sparse - 1.7 * 10^-3 foreground pixels / pixel. Also the contest used 4 component images, while my images are thresholded, black and white. Plus, for blob extraction, I don’t need to explicitly label all foreground pixels - just need to know they’re connected.
There’s a very delicate balance between ||ism and work efficiency. I tried many granularities for ||ization and in general, the added ||ism
you get by dividing the blocks smaller can easily be canceled by the extra merge costs.
As I stated above, whether your input will have large #vertices or large #edges will really affect what’s the best algorithm.
Thanks for the help, the problem sounds more general than the one I’m trying to solve but its probably worth having a look at how he tackled the problem.
By chance, is that part of your code available online ?
