Hello. I’ve got a code of the form:
switch(foo) {
case 1:
do1();
break;
case 2:an
do2();
break;
case 3:
do3();
break;
The actual code is too complex to post right now. The complexity of do1(), do2(), and do3() are pretty similar. If I comment out any one of the three cases, the code compiles, and the .cubin file says my overall global function uses the following resources:
The resources are the same whether I leave one or two cases in the code. But if I leave all three cases in the code, nvcc crashes with the following output:
### Assertion failure at line 2268 of ../../be/cg/NVISA/cgtarget.cxx:
### Compiler Error in file /tmp/tmpxft_00000c88_00000000-4.i during Register Allocation phase:
### ran out of registers in integer64
*** glibc detected *** /usr/local/cuda/open64/lib//be: free(): invalid pointer: 0x0000000000f97560 ***
======= Backtrace: =========
/lib64/libc.so.6[0x37cec6f504]
/lib64/libc.so.6(cfree+0x8c)[0x37cec72b2c]
/usr/local/cuda/open64/lib//be[0x570fa0]
/usr/local/cuda/open64/lib//be[0x594aa8]
/lib64/libc.so.6(exit+0xe5)[0x37cec32eb5]
/usr/local/cuda/open64/lib//be[0x684f4a]
/usr/local/cuda/open64/lib//be[0x514c4e]
/usr/local/cuda/open64/lib//be[0x514dfd]
/usr/local/cuda/open64/lib//be[0x524b9a]
/usr/local/cuda/open64/lib//be[0x419b5d]
/usr/local/cuda/open64/lib//be[0x419f4d]
/usr/local/cuda/open64/lib//be[0x41b182]
/lib64/libc.so.6(__libc_start_main+0xf4)[0x37cec1d8a4]
/usr/local/cuda/open64/lib//be[0x417609]
======= Memory map: ========
00400000-00802000 r-xp 00000000 fd:04 8716431 /usr/local/cuda/open64/lib/be
00a01000-00c54000 rw-p 00401000 fd:04 8716431 /usr/local/cuda/open64/lib/be
00c54000-03167000 rw-p 00c54000 00:00 0 [heap]
37ce800000-37ce81a000 r-xp 00000000 fd:04 23167001 /lib64/ld-2.5.so
37cea19000-37cea1a000 r--p 00019000 fd:04 23167001 /lib64/ld-2.5.so
37cea1a000-37cea1b000 rw-p 0001a000 fd:04 23167001 /lib64/ld-2.5.so
37cec00000-37ced46000 r-xp 00000000 fd:04 23167003 /lib64/libc-2.5.so
37ced46000-37cef46000 ---p 00146000 fd:04 23167003 /lib64/libc-2.5.so
37cef46000-37cef4a000 r--p 00146000 fd:04 23167003 /lib64/libc-2.5.so
37cef4a000-37cef4b000 rw-p 0014a000 fd:04 23167003 /lib64/libc-2.5.so
37cef4b000-37cef50000 rw-p 37cef4b000 00:00 0
37cf000000-37cf082000 r-xp 00000000 fd:04 23167210 /lib64/libm-2.5.so
37cf082000-37cf281000 ---p 00082000 fd:04 23167210 /lib64/libm-2.5.so
37cf281000-37cf282000 r--p 00081000 fd:04 23167210 /lib64/libm-2.5.so
37cf282000-37cf283000 rw-p 00082000 fd:04 23167210 /lib64/libm-2.5.so
37d1000000-37d100d000 r-xp 00000000 fd:04 23167216 /lib64/libgcc_s-4.1.2-20070626.so.1
37d100d000-37d120d000 ---p 0000d000 fd:04 23167216 /lib64/libgcc_s-4.1.2-20070626.so.1
37d120d000-37d120e000 rw-p 0000d000 fd:04 23167216 /lib64/libgcc_s-4.1.2-20070626.so.1
37d3800000-37d38e6000 r-xp 00000000 fd:04 8749090 /usr/lib64/libstdc++.so.6.0.8
37d38e6000-37d3ae5000 ---p 000e6000 fd:04 8749090 /usr/lib64/libstdc++.so.6.0.8
37d3ae5000-37d3aeb000 r--p 000e5000 fd:04 8749090 /usr/lib64/libstdc++.so.6.0.8
37d3aeb000-37d3aee000 rw-p 000eb000 fd:04 8749090 /usr/lib64/libstdc++.so.6.0.8
37d3aee000-37d3b00000 rw-p 37d3aee000 00:00 0
2aaaaaaab000-2aaaaaaac000 rw-p 2aaaaaaab000 00:00 0
2aaaaaad4000-2aaaaaad7000 rw-p 2aaaaaad4000 00:00 0
2aaaaacd4000-2aaaaacd5000 rw-p 2aaaaacd4000 00:00 0
2aaaaacd5000-2aaaaad5c000 rw-p 2aaaaac55000 00:00 0
2aaaaad5c000-2aaaaad5e000 rw-p 2aaaaad5c000 00:00 0
2aaaac000000-2aaaac021000 rw-p 2aaaac000000 00:00 0
2aaaac021000-2aaab0000000 ---p 2aaaac021000 00:00 0
7fff34108000-7fff341ee000 rw-p 7fff34108000 00:00 0 [stack]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vdso]
Signal: Aborted in Register Allocation phase.
Error: Signal Aborted in phase Register Allocation -- processing aborted
*** Internal stack backtrace:
/usr/local/cuda/open64/lib//be [0x684b0e]
/usr/local/cuda/open64/lib//be [0x685ed7]
/usr/local/cuda/open64/lib//be [0x68576c]
/usr/local/cuda/open64/lib//be [0x6858d1]
/usr/local/cuda/open64/lib//be [0x686581]
/lib64/libc.so.6 [0x37cec300c0]
/lib64/libc.so.6(gsignal+0x35) [0x37cec30065]
/lib64/libc.so.6(abort+0x110) [0x37cec31b00]
/lib64/libc.so.6 [0x37cec6825b]
/lib64/libc.so.6 [0x37cec6f504]
/lib64/libc.so.6(cfree+0x8c) [0x37cec72b2c]
/usr/local/cuda/open64/lib//be [0x570fa0]
/usr/local/cuda/open64/lib//be [0x594aa8]
/lib64/libc.so.6(exit+0xe5) [0x37cec32eb5]
/usr/local/cuda/open64/lib//be [0x684f4a]
/usr/local/cuda/open64/lib//be [0x514c4e]
/usr/local/cuda/open64/lib//be [0x514dfd]
/usr/local/cuda/open64/lib//be [0x524b9a]
/usr/local/cuda/open64/lib//be [0x419b5d]
/usr/local/cuda/open64/lib//be [0x419f4d]
/usr/local/cuda/open64/lib//be [0x41b182]
/lib64/libc.so.6(__libc_start_main+0xf4) [0x37cec1d8a4]
/usr/local/cuda/open64/lib//be [0x417609]
nvopencc INTERNAL ERROR: /usr/local/cuda/open64/lib//be died due to signal 4
I can probably work more on trying to turn the code into a small example. Any ideas? I haven’t tried it in 1.1 yet (1.1 had other link errors for me before, so I’m hesistant to reinstall again).
